12-13-2009, 05:29 PM   #1
green button to set exposure
Hi,
Being playing with a super tak I recently got on the k-x for a while now. After reading up on using the green button to set exposure, I have also read that the (+-) can also set exposure, I did a quick test to find both will set exposure in M mode. but, the exposure set is almost always wrong.
Since I am new, I figure green button will give me a ball park figure to start with. But, it is so off that it is not useful at all.
Here is what I did:
1) turn C menu #22 to 2 -- which allows use of aperture ring
2) turn camera off and set to M mode
3) put lens on
4) turn on
5) some times, it will ask for focal length... but most of the time, it won't
I stop down to say f22 and hit the green button/(+-) button. It always set to 1.6" for me. I then stop to f3.5 and hit the green button, it does not change from 1.6"
Am I doing anything wrong?
Thanks
12-14-2009, 10:43 AM   #2
Marc Sabatella's Avatar
I assume the Super tak is a screw mount lens mounted vi n adapter? The procedure for using those is totally different. If you browse around, you should be able to find instructions. Hint: it depends on if your lens has a "manual / auto" switch and where you position it.
BTW: the cameras should ask for focal length if SR is turned on; it won't if SR is turned off. Presumably that includes use of the timer modes that automatically disables SR.
12-14-2009, 02:05 PM   #3
thanks! I will try the SR non SR bit and see. the lens is set to manual since I don't recall k-x is able to push the pin. I will search some more
12-14-2009, 08:25 PM   #4
I *believe* in Manual mode on the lens, you wouldn't use M mode and Green button on the camera - since as you say, the camera can't stop the lens down anyhow - but instead simply use Av mode and live with the fact that the viewfinder darks as you turn the aperture ring.
button, camera, exposure, figure, mode, pentax help, photography
Stop Down Metering With The Green Button: Wrong Exposure Recomendations Obs Troubleshooting and Beginner Help 55 03-27-2015 09:39 AM
Green button fekish Troubleshooting and Beginner Help 4 10-06-2010 03:33 PM
k10d - can i adjust green-button-exposure measuring? teson Pentax DSLR Discussion 9 07-07-2010 08:39 AM
Green Button res3567 Pentax DSLR Discussion 16 04-07-2009 11:41 PM
K10D Exposure w/Green Button in M mode carpents Pentax DSLR Discussion 28 04-28-2007 05:46 PM
All times are GMT -7. The time now is 07:05 AM. | See also: NikonForums.com, part of our network of photo forums!
