12-14-2009, 04:18 PM   #1
Location: City of Elliot Lake (North Eastern) Ontario, Canada
Lens won't focus
SMC Pentax-FA 1:4 28-70mm AL
When I mount this lens it will not focus.
It either rolls left and right or if it does stop, the Green focus indicator does not stop blinking and focus is not achieved.
To get the camera to focus I must turn the Aperture ring off and on. Sometimes it takes several tries.
I have swabbed the contacts with alcohol.
None of my other lens' have the problem, so it's not with my K10D
Any suggestions? .
12-14-2009, 05:02 PM   #2
Are you able to obtain focus with manual focus? One of the elements inside the lens might have moved out of position, keeping the lens from obtaining proper focus.
12-14-2009, 06:28 PM   #3
QuoteOriginally posted by flyer Quote
YES I can.Sometimes with the green indicator appearing, sometimes without but manual focus is OK.And as I mentioned earlier, auto focus works fine after I fiddle with the apeture ring, releasing and resetting, sometimes it takes several tries. When it finally settles down it works fine.
12-14-2009, 09:29 PM   #4
Did you try cleaning the electrical contacts on the lens mount?
GP
12-15-2009, 01:47 AM   #5
Yes. As I had said I swabbed the contacts with alcohol. Is there a better way?
12-15-2009, 06:54 AM   #6
Alcool won't take off oxydation, Try a soft eraser.
12-15-2009, 02:45 PM   #7
Not hard to tell that I'm no yosouf Karsh.
The contacts were not the problem. But following your suggestions I hauled out a magnifying glass to look at the contacts then compared them with anothere lens' while waving the magnifying lass around I chanced on the bent lever. No idea what it's called but after whacking it with a ball pein hammer, the lens behave as it should.
Can't say how the bent lever happened or when but must have bumped it pretty hard to bend it that way. I my defense, I bought the lense new and seldom had a need to use it.
But thanks for pointing me in the right direction.
camera, focus, lens, pentax help, photography
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
FA Limited lens series won the 2010 Good Design Long Life Design Award Patriot Pentax SLR Lens Discussion 26 11-29-2010 06:16 AM
So who won the Lens off Ebay?? Fl_Gulfer Pentax SLR Lens Discussion 6 12-06-2009 08:56 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
Ooops, won 2 135mm m42 lens, which one should I keep? reknelb Pentax SLR Lens Discussion 2 02-25-2007 11:12 AM
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
