12-18-2009, 04:38 PM   #1
Whats the difference?
I was in B&H looking for some lens.
I came across some Pentax lens.
pentax 18-55mm f/3.5-5.6
Looking at the link. What are the differences between the two.
I plan to use the lens for shooting video with the Canon 7D.
Thanks
12-18-2009, 04:41 PM   #2
They are different: one is weather-resistant, one is not.
They are the same: don't work with Canon bodies.
12-18-2009, 04:43 PM   #3
QuoteOriginally posted by SOldBear Quote
Really? What about getting an adapter?
What about the m42 Adapters?
I also plan to get the 50mm f1.4 Super Takumar.
On those you can get an adapter.
12-18-2009, 04:53 PM   #4
mtroute's Avatar
QuoteOriginally posted by Nathandajet Quote
No K-mount to Canon adapter available that I know of.
You will need to get an m42 to K-mount adapter for the Super Taks
12-18-2009, 04:54 PM   #5
You might be able to find an adapter to use Pentax KAF2 lenses on a Canon body (I don't know of any, but that doesn't mean it doesn't exist). But I bet you that you will lose all automatic functions (meter, focus). For these particular lenses, which does not have aperture ring, you can't even control the aperture. I wouldn't bother even if I could find that adapter.
But the lenses referred to in your original post are not M42 lenses.
I realize that there exists adapters to use M42 lenses on a Canon body. But again, everything will be manual.
12-18-2009, 04:56 PM   #6
Well if the Pentax 18-55mm Lens don't fit on the 7D.
Then what other M42 lens can I get with a Wide zoom lens similar size.
I'm looking for a range in 100-200.
12-18-2009, 04:58 PM   #7
I think that everything is Manuel while filming in video mode on the 7D. Even if you get an AF lens.
12-18-2009, 04:58 PM   #8
mtroute's Avatar
The 18-55mm is not a M42 lens, it is a K-mount.
edit: I mis-understood the ? There are many many M42 lenses out there from a number of manf.
12-18-2009, 05:01 PM   #9
QuoteOriginally posted by mtroute Quote
How would you know it has a m42 fitting?
12-18-2009, 05:03 PM   #10
LeDave's Avatar
It's neat to spend over 1600 on your first DSLR, I wish I could do the same =(
12-18-2009, 05:06 PM   #11
QuoteOriginally posted by LeDave Quote
It's my first Camera.YES.
But I'm mostly going to use it for Video.
12-18-2009, 05:17 PM   #12
Wow what a great community this is.
I even posted it under Beginner's Corner.
So doesn't that tell you something.
12-18-2009, 05:20 PM   #13
Let's not fight.
Use canon lenses on canon bodies. Amazon.com: Canon EF-S 18-55mm f/3.5-5.6 IS SLR Lens: Camera & Photo. 7D can do a 'slow hunt' autofocus, but I recommend avoiding it at all costs.
12-18-2009, 05:26 PM   #14
QuoteOriginally posted by erickallemeyn Quote
Let's not fight.
Thanks.
I was actually looking at those.
HEre is a shot using the 7D with the same lens.
I might have posted in a wrong site.
Maybe I should go with a Canon site.
This is for Pentax lovers.
But then why is DVXUSER.com so good?
12-18-2009, 05:27 PM   #15
So let me get it straight.
Lens that are the same brand will be able to use AF but if you cross over it's all Manuel?
18-55mm, camera, lens, pentax, pentax help, photography
Whats the Difference between the Pentax 50-135mm vs the 50-200mm or 55-300mm rustynail925 Pentax SLR Lens Discussion 2 03-12-2010 11:47 AM
Whats this? bentax Pentax DSLR Discussion 4 07-07-2009 04:56 PM
whats the difference? 1:1 vs. 1:2 macro metungnasi Pentax SLR Lens Discussion 15 04-06-2009 04:16 PM
whats going on here? Gooshin Pentax SLR Lens Discussion 10 07-05-2008 06:04 PM
whats the difference between rmtagg Pentax Camera and Field Accessories 3 03-20-2008 08:16 PM
All times are GMT -7. The time now is 03:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
