12-19-2009, 12:56 PM   #1
Can you disable continuous shooting?
Hi - this is probably in the manual but I didn't download it and I don't have the camera yet!
I was in the store trying a K-x and I ended up firing the shutter several times when I just meant to take one shot... man that thing is fast! So, is there a setting to disable the continuous shooting, or do I just have to train my trigger finger?!
This happened several times and could get annoying if I don't want strings of shots... Thanks.
12-19-2009, 01:08 PM   #2
Marc Sabatella's Avatar
Yes, certainly. Not sure about the K-x, but on most other Pentax cameras, you hit the Fn button then the "up" arrow to get to the drive mode screen.
12-19-2009, 02:00 PM   #3
Same thing in the K-X. Push the four-way up and you'll open the drive mode screen.. Choose single from there.
12-19-2009, 04:58 PM   #4
GerryL's Avatar
On the K100D super, as mentioned previously, it has single, continous, 2 sec timer, another timer (12 sec, I think..actually forgot).
12-19-2009, 10:30 PM   #5
Canada_Rockies's Avatar
QuoteOriginally posted by GerryL Quote
Not to mention 3 sec and instantaneous remote settings. The short self timer and remote settings lock up the mirror at the beginning of the timer, and release the shutter 2 or 3 seconds later, reducing vibration when shooting on a tripod.
12-19-2009, 11:00 PM   #6
can you do mirror lock up when triggering from remote?
12-19-2009, 11:59 PM   #7
Barnster's Avatar
The best thing to do is to read the manual to see what your can and can't do.
12-20-2009, 12:29 AM   #8
QuoteOriginally posted by Sight Quote
2 sec self timer and 3 sec remote are the two mirror lockup settings on my k10d. I am using the Remote F, so I use the 3 sec setting. If I were to spring for a cable release (a bit more reliable in bright light) I would need to use the 2 sec self timer setting.
Hope this helps.
12-20-2009, 01:24 AM   #9
Well, I choose to train my finger, as it's way easier than going in the drive menu when you need continuous!
12-20-2009, 02:13 PM   #10
Thanks for all your quick answers guys. Good to know I won't always end up with duplicate shots by mistake! I figured it would be that way, but I didn't immediately figure it out while briefly playing with one in person.
12-20-2009, 04:08 PM   #11
GerryL's Avatar
QuoteOriginally posted by dlacouture Quote
I also do this rather than set it to a per shot basis.
camera, pentax help, photography, times
Continuous shooting fekish Pentax DSLR Discussion 8 09-24-2010 05:58 AM
K-7 Continuous Shooting brosen Pentax DSLR Discussion 17 08-29-2010 06:24 PM
Help with continuous shooting mode! PentX Girl Pentax DSLR Discussion 6 02-17-2010 04:26 PM
Continuous shooting with K10D Green_Manelishi Pentax DSLR Discussion 18 04-05-2009 11:28 AM
Continuous shooting sound furby Pentax DSLR Discussion 1 09-09-2008 03:42 AM
All times are GMT -7. The time now is 05:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
