12-26-2009, 01:08 PM   #1
"A" lens and SR and focal length?
Hi,
I can't find it in search. When using "A" lens, with SR on, if will record length in exif. but, with SR off, it won't. I know camera needs to know length for SR reasons. But, why can't it just keep the length till changed in the exif? After all, you can certainly fool it by turning off SR then change to another non-FA lens no?
This seems like a firmware changeable item? The reason being, at times, handheld with flash on or high shutter speed, SR gives me soft pics. I am not going to discuss k-x gives soft pics as there are other threads dedicated for that topic. But, my own experience, A/B shots with SR with out SR with flash on, the ones with SR are more prone to slight blur. But, turning SR off won't give me focal length recording thus harder to sort through my pics.
thanks
12-27-2009, 01:43 PM   #2
You are quite right that technically it could probably be done in the firmware.
I think the main reason why Pentax does not is programmatically, it is much easier to do:
IF SR=on, then write FL into EXIF ELSE not.
Otherwise it is more complicated (SR is off, but was on since the last time the lens was changed, etc...)
Not impossible, but they decided not to do it.
12-27-2009, 02:41 PM   #3
Canada_Rockies's Avatar
QuoteOriginally posted by Diffusion Quote
And if they had done it, somebody (obviously not anyone on these forums!) would change lenses with SR off and complain that the lens was reported as 28mm when it was actually 400.
camera, exif, flash, length, lens, pentax help, photography, pics, sr
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 33 02-10-2016 09:10 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
which focal length(s) are considered "fish eye"? slip Pentax SLR Lens Discussion 3 12-13-2006 10:51 AM
All times are GMT -7. The time now is 04:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
