12-28-2009, 07:02 AM   #1
Sigma 28mm 1.8 on K1000
I have a Sigma 28mm 1.8 DG EX on order for the digital. The only film K mount I have at present is a K1000. Can this lens be safely mounted on this body? And, can it be used as if it were an "M" lens?
Thanks,
Charles
12-28-2009, 12:48 PM   #2
Canada_Rockies's Avatar
To use it on the K1000 film camera, it will need to have an aperture ring, as the early K SLRs have no way to read the electronic aperture signals. If it has an aperture ring, then the camera can read that, and you can use it in the same ways, with the same limitations as an M or K series lens.
12-28-2009, 01:58 PM   #3
QuoteOriginally posted by Canada_Rockies Quote
Yes, this one does. I just wanted to make sure that there weren't some kind of contacts or linkages in autofocus lenses that tht might be damaged by a manual mount.
12-28-2009, 02:05 PM   #4
Ratmagiclady's Avatar
QuoteOriginally posted by c a sugg Quote
You're good. Got one of these lined up, myself.
You will find it convenient, by the way, to have the lens off the 'a' setting before you mount it to the K1000, is all. (Easiest done just before you unmount the lens from your digital.) But congratulations, you're in compatibility-land.
28mm, camera, k1000, lens, pentax help, photography, sigma, sigma 28mm
For Sale - Sold: Spotmatic, K1000, Sigma 24-70 2.8 dg and more (US/CAN) Andrew Lang Sold Items 0 08-10-2010 06:55 PM
Sigma 28mm f/1.8 and Sigma 30mm f/1.4: 3 Questions Biro Pentax SLR Lens Discussion 0 03-06-2010 03:12 PM
Sigma 28mm F1.8 Gooshin Pentax SLR Lens Discussion 5 08-26-2008 10:51 AM
sigma 28mm ex f1.8? Geekybiker Pentax SLR Lens Discussion 5 04-09-2008 06:17 PM
All times are GMT -7. The time now is 10:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
