12-29-2009, 11:04 PM   #1
joodiespost's Avatar
Battery Usage Question
Hi folks, I was going through the settings last night with my K-x. I was wondering how much of a battery drain difference will there be with the Blue lamp on high low or off? And the same question goes for the theme colors. Will a darker theme drain less battery than a bright theme? ie White on white. Or are these all negligible?
12-30-2009, 10:46 AM   #2
I'm going to say the power consumption with the blue lamp and changing the color theme is negligible. However, in my opinion live view and the big LCD which tells the camera setting with cause battery drain. Similar to that of P&S cameras. I have my KM with all those setting off and noticed no significant difference in battery life. I do have the big LCD off due to the fact that at night it's annoying.
12-30-2009, 11:10 AM   #3
thanks for the input. As this is my first camera, I couldn't really test out the differences but I left mine at full brightness setting with no pic review after shot. The color theme is the original one and blue light is default. This battery seems to lasts quite a while, about 3 days. It's been about 3 weeks since I got my camera and I've already taken about 2067 pictures. So I do use it quite a bit. I'm going to have to try out a different color theme to see if that makes a difference.
battery, camera, drain, pentax help, photography, question, theme
newbie question about remote usage on k-x 96p993 Troubleshooting and Beginner Help 2 08-09-2010 10:06 PM
K-7 battery question dkaym Pentax DSLR Discussion 4 04-27-2010 07:09 AM
Another (different) battery question bniece Pentax DSLR Discussion 3 11-22-2009 09:00 PM
K100D excessive battery usage. blwnhr Pentax DSLR Discussion 36 04-04-2009 12:47 AM
Question re the battery JamesAus Pentax DSLR Discussion 5 06-25-2007 04:00 PM
All times are GMT -7. The time now is 10:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
