01-07-2010, 11:41 AM   #16
QuoteOriginally posted by atown Quote
But...that kinda blows the whole purpose of having a P-TTL auto-exposure flash, so then you may as well set it manually by the guide number, if you have to get the right exposure by trial and error with EV compensation ! Also makes "candid" shots a lost cause.
I have a couple of old auto flashes (Pentax AF200T and AF330FTZ, and Vivitar auto thyristor 3700) that I could try out, but am a bit leery of the trigger voltage issues... I don't want to fry my K10D ! So, has anyone tried any of those flashes, either in auto or manual mode, and are they safe ?
Thanks to all responders !
Alan
If you own the flash, you should just spend a couple of bucks on a DVM and measure it your self. a cheapy meter from the shack will get you in the ball park. red on center pin and blk on the side of the shoe. After the flash charges, fire off a test flash then wait till the 2nd charge measure when the flash is ready. anything under 6V is safe. above 6 but below 24, your call. above 24, I won't try it.
01-07-2010, 04:43 PM   #17
GerryL's Avatar
Alan
I'm just saying "kinda" because the flash goes on to full power to compensate for the bounce since it has to get as much light it has since you have to deflect the light.
The camera still does P-TTL to get the correct exposure.
I've posted some shots for you so you can see for yourself.
All these where bounced off the ceiling that was 10ft.
ISO was set at 400 and I made it only 4MP due to attachment limits.
The first two was angled about 60 degrees and the third was at 90 degree (100% vertical) bounce! You can see the shadow on the lamp on the third photo going down.
The room was in almost total darkness and the AF assist of the flash nailed the focus and fast!
Judge for yourself if it is underexposed.
I'll try to attach the pix without resizing but if I can't then there is no PP but only resizing on the pix.
I blurred out some areas on purpose (the only PP) 'coz of personal identification and personal information on the receipts.
01-07-2010, 04:46 PM   #18
GerryL's Avatar
Alan
I have read somewhere that all the Pentax flashes are still compatible with the voltage.
I wouldn't recommend on using the Vivitar though without actually testing the voltage.
Someone more knowledgeable about these Pentax flashes would probably give a better response.
01-12-2010, 08:54 PM   #19
mattdm's Avatar
QuoteOriginally posted by GerryL Quote
The Tumax made flashes by the way kinda lose their P-TTL when bounced (when flash head is angled, automatic flash setting place it on "manual") since the flash goes to full manual power (compensating for the bounce).
Oh, wow, I wasn't aware of that can anyone double-confirm this? That's a serious drawback for these models that I should highlight on my guide. (For the Sigma, Pentax, and Metz models, it's very arguable that P-TTL works best with bounced flash.)
01-15-2010, 10:52 AM   #20
GerryL's Avatar
QuoteOriginally posted by mattdm Quote
Matt, I'm not really sure if you can call it that (losing P-TTL) but it does disengage (maybe because of the zoom) and locks the setting to 50mm zoom setting and I would bet full power to compensate for the bounce.
I haven't done a complete test though so, don't make conclusions.
Here is the description on the manual.
*I think this was discussed too here in the forum fairly recently about the Pentax OEM P-TTL flashes doing the same (losing P-TTL during bounce or swivel).
I'll look for that thread and post the link here too.
01-15-2010, 11:04 AM   #21
GerryL's Avatar
Found the thread I was talking about Matt.
It's kind of a controversy how P-TTL really works as with what I just mentioned about the Tumax flashes seem to be the same with the Pentax flashes.
Here's the link to the discussion: https://www.pentaxforums.com/forums/general-photography-techniques-styles/867...otography.html
You know better than me, I suppose, so you can draw your own conclusions.
01-15-2010, 12:26 PM   #22
Is Rokinon D980AFZ-P P-TTL or just TTL ?
Welcome to the forums Gjmcd.
I have the Bower SFD 926P and it is the same as the Vivitar DF 383 or the Rokinon or the Digital Concepts with the LCD back.
They all work P-TTL
These flashes are exactly the same except for some minor cosmetic/appearance differences because they are all made by Tumax.
Are you sure the Rokinon D980AFZ-P is P-TTL ? The Overstock ad just says TTL, and I read somewhere else it does not do P-TTL exposure.
01-15-2010, 03:56 PM   #23
GerryL's Avatar
It is P-TTL atown!
Sure as sure as can be it's P-TTL as I have the Bower variant/clone/rebrand/subcontracted type.
All those flash units are made by a company called Tumax.
When they brand it/make it for Pentax, they make it P-TTL, so be sure to get the Pentax one..not for Canon or Nikon or Olympus or Sony as they make them for these brands too!
If they make it for other brands, they make it compatible or dedicated for that brand.
This is the same for the Bower or Digital Concepts or Vivitar or Rokinon for that matter.
The power zoom type are the ones with the LCD back.
The manual zoom type are the ones with the simple LED indicator lights.
Go to the site of Tumax I linked on the above posts so you can see that they make these flashes dedicated for whatever brand they make it for.
01-15-2010, 04:05 PM   #24
GerryL's Avatar
Matt, I just did a simple test and it actually doesn't lose the P-TTL when you have set it on that automatic P-TTL (TTL on the generic LCD screen).
I angled the bounce head in a very small increment only enough to lock the zoom head to 50mm thinking I angled it 45 degrees or more upwards.
I, in actually just angled it like 5-10 degrees off the horizontal, so it basically still bursts its lights forward.
I took a photo of an item and went closer for each shot until I was almost in macro mode (using the DA18-55mm).
The flash still produced the right amount of exposure and the power output of the flash still varied depending on how near you are the subject you are shooting.
More power when afar the subject and barely using enough power when close up.
Tumax made them to specs, I guess!
I'm actually glad I bought this flash now!
01-15-2010, 04:13 PM   #25
GerryL's Avatar
I can post you part of the manual too like the above attachment I made so you can see the instructions for different camera brands.
They give only one generic intruction manual, I believe, for every variant that they sell whether it be for Pentax, Oly, Sony, Canon or Nikon.
If you have further questions, just post them and I'll get back to them when I get the time.
Sigma 530 Super flash doesn't fire multi flash, any advice? pasipasi Pentax DSLR Discussion 4 11-25-2010 02:04 AM
For Sale - Sold: Metz 48 AF-1 Flash; Pentax off-camera flash cable set (Adapter F, FG (US/UK/CA bigben91682 Sold Items 4 10-12-2010 04:23 AM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
For Sale - Sold: Pentax AF200S flash, Vivitar 2800 macro flash, Lowepro Lens case 4 Light_Horseman Sold Items 8 03-06-2010 10:13 AM
For Sale - Sold: Pentax TC's, Kenko TC, SF10 (x2), AF540 flash, Promaster FTD 7000M flash Marc Langille Sold Items 17 08-16-2008 10:29 AM
All times are GMT -7. The time now is 02:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
