01-03-2010, 03:09 PM   #1
Nooby with grainy photos
Hi,
Just started taking simple photos with my K2000 (18-55 lense) and all the photos are very "grainy" (see attached).
current settings:
JPEG REC. PIXELS 10M
Sensitivity 3200
JPEG quality ***
JPEG
Where do I start? I expected very clear photos and need help. Thanks
01-03-2010, 03:44 PM   #2
Damn Brit
Guest
You have ISO set at 3200, try 400 to start with. The lower the number the less grain you will get but the more light you will need.
A good read of the manual will help you. If you've already read it, read it again.
There are no pictures attached by the way.
01-03-2010, 03:45 PM   #3
GerryL's Avatar
Welcome plucci!
Is it just me or I can't really see anything attached?
Shooting at high ISO and at low light usually produces grainy pix.
Now, if I can only see the picture attached then we can see it for sure!
01-03-2010, 03:48 PM   #4
GerryL's Avatar
QuoteOriginally posted by Damn Brit Quote
Aha! So, it is not just me!
Whew!!! I thought there for a moment that something was wrong with my browser or something.
01-03-2010, 05:40 PM   #5
Grainy photos
Sorry - struggling to save the photo to a format that meets the file size limitations.
The ISO change made a huge difference.
Can someone suggest ideal settings for shooting basketball action photos with a 18-55 lense? Is there a way I can determine the quality of the photo while taking it, so I don't have to go through this trial and error process. The photos looked fine on the veiwfinder.
Read the 300 pg maual??? I have read many sections including the troubleshooting section to resolve this issue - no good suggestions found.
But, you helped me and I will return for more help in the future! Thanks!
01-03-2010, 06:07 PM   #6
Damn Brit
Guest
QuoteOriginally posted by plucci Quote
Ideal settings with that lens would be ISO 3200 and grainy pictures probably. It doesn't have a wide enough aperture.
Get a good book like Bryan Peterson's 'Understanding Exposure' or 'Understanding Photography Field Guide'.
The issue isn't with your camera, it's your lack of experience. Trial and error will only get you so far, the books will help you progress beyond that. It's fine to ask questions here but at the moment you don't necessarily know what are the best questions to ask. A good book will answer those questions for you. Consider us as backup to the books.
Here's some help with uploading images - https://www.pentaxforums.com/forums/post-your-photos/6-read-first-how-post-up...de-images.html
more reading I'm afraid.
01-03-2010, 07:56 PM   #7
dadipentak's Avatar
Shooting hoops is hard. I'm not sure what level you're shooting but the light in a lot of those gyms is really atrocious. I shoot my daughters games with a fast 50mm prime at around f3.5 and a shutter speed of 1/320s or faster to eliminate motion blur. I let the K20D take ISO as high as it wants. My shots are grainy and I use pretty heavy handed Noise Reduction in PP. The results aren't SI quality but I figure, as long as I'm catching good action, a little waxiness in the skin texture isn't a huge deal.
01-04-2010, 09:09 AM   #8
Marc Sabatella's Avatar
The "grain" (actual term: noise) would have been visible on the LCD after taking the picture had you zoomed in.
Anyhow, low light is hard. You need fast shutter speeds to avoid blur, but there are only to ways to get fast shutter speeds: wide apertures (low f-numbers) or high ISO. And the 18-55 doesn't allow particular wide apertures. That's why you see people talking about getting "fast" lenses - lenses with maximum apertures of f/2.8 or better, rather than f/5.6, which is all the 18-55 can do at the long end (it's a little better in the middle of the range). these lenses are called "fast" because they allow faster shutter speeds. But realistically, even with faster lenses, you'll still need high ISO. You'll just have to experiment to find the best balance - where you can set ISO to give you an acceptable tradeoff between noise from high ISO and blur from low shutter speeds.
01-04-2010, 09:47 AM   #9
Ratmagiclady's Avatar
Agreed, there. Especially on what to expect shooting basketball with a lens that slow: 'graininess' is a lot better than the other tradeoffs.
Personally, I was never opposed to 'grain' in the first place, the only question being 'does it look pleasant,' ...especially with indoor sports, it's not the object of the game for it to not look like a photograph, if you asked me. Just concentrate on hitting your shots for now, given what you're working with.
I actually shoot a lot of high-ISO when I don't even need to, ...I like some texture, ....as long as it doesn't look like bad TV reception or an ersatz film grain effect or something. Especially in monochrome, the noise isn't too unpleasant, as far as I'm concerned. I'm OK up to 3200 on my K20d, mostly: 6400 tends to be a wash, cause of patterns that'll crop up.
RML's Rule One of Photography: Get The Shot.
Lighting conditions in most non-pro basketball venues are usually ones where you don't get to pick and choose your ISO ratings. Just do what you have to.
01-04-2010, 02:35 PM   #10
Ash
Community Manager
Ash's Avatar
Indeed you've exceeded the kit lens's capabilities in capturing a sharp action shot in low light conditions. This is why upgrading to a 'faster' lens with larger maximum aperture is valuable. Until camera bodies come out with manageable noise at ISO 12800, there is no other substitute to get good action photos.
camera, jpeg, pentax help, photography, photos
K-m model - grainy photos mwc Pentax DSLR Discussion 9 09-07-2010 09:28 AM
Spotmatic SP1000(Nooby sorry) glsmith Troubleshooting and Beginner Help 6 12-03-2009 08:58 PM
Grainy Viewfinder ingi Pentax DSLR Discussion 8 06-25-2008 04:21 AM
grainy photos strictlypentax Photographic Technique 21 06-10-2007 08:45 AM
Help! why is this photo so grainy? NaClH2O Pentax DSLR Discussion 25 01-05-2007 11:53 PM
All times are GMT -7. The time now is 11:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
