01-03-2010, 03:47 PM   #1
pakuchn's Avatar
How to check shutter count on K20D
Hello,
How do you check shutter count on a K20D?
Thank you.
I just want to add that PhotoMe, did not show the picture.
01-03-2010, 03:58 PM   #2
PFH
PFH's Avatar
This program works just fine.
PhotoME - Exif, IPTC & ICC Metadata Editor
01-03-2010, 04:01 PM   #3
pakuchn's Avatar
That is what I told my friend to do, but he says that his last photo says img0003
01-03-2010, 04:15 PM   #4
PFH
PFH's Avatar
Mine works perfect.
In "Open file" I open my last image, then i just write "shutter" in the find field in the bottom. Then the shutter count appears in the field above
01-03-2010, 04:24 PM   #5
pakuchn's Avatar
I'll let him know to try that. Can shutter count be reset back to ZERO?
01-03-2010, 04:26 PM   #6
PFH
PFH's Avatar
I donīt think that is posible.
01-03-2010, 04:43 PM   #7
pakuchn's Avatar
How about this question. If my friend would email me latest picture taken, what can I do at home to check shutter count?
please note that his current image says IMG 0003.
01-03-2010, 04:56 PM   #8
PFH
PFH's Avatar
QuoteOriginally posted by pakuchn Quote
As long as the exif and IPTC are kept with the image there should be no problem.
That means donīt use the function "Save for the net" in PS, just resize it and save the image as usual.
The name IMG 0003 have nothing to do with the shutter count.
01-03-2010, 08:50 PM   #9
noblepa's Avatar
That sounds like the file number, not the shutter count. The file name (number) can be reset, but the shutter count can not.
The shutter count is not displayable by the camera, nor is it an external part of the image, the way the file name is. The shutter count is ONLY visible in the EXIF data of each image. You need a program like PhotoME, Opanda, or Exiftools to display the data. Some photo editting software will show the EXIF data, as well.
I use Exiftools. Here is a snip of the output:
Shutter Count : 4308
01-03-2010, 08:53 PM   #10
pakuchn's Avatar
Got it. Thank you.
08-26-2010, 02:29 PM   #11
mulanrouge's Avatar
Someone's got dibs.
Shutter count (finally): 3617.
Update to follow.
02-06-2011, 02:08 PM   #12
As follow-up, is there any easy way to learn from scratch about how to get shutter count on a K20D on a Mac?
I've never obtained shutter count for any Pentax body and am starting from the beginning.
Many thanks.
02-06-2011, 05:45 PM   #13
darrenleow's Avatar
QuoteOriginally posted by Biff Quote
Many thanks.
Check shutter count online - My Shutter Count.com
02-06-2011, 06:57 PM   #14
Excellent, that's pretty simple.
Thanks!
camera, check, check shutter count, count, k20d, pentax help, photography, shutter
How to check shutter actuations on K20D pakuchn Pentax DSLR Discussion 9 01-04-2010 03:10 PM
For Sale - Sold: K20D Body in Canada, LOW shutter count. ianinbc Sold Items 3 11-17-2009 05:54 AM
New K20d Shutter Actuation Count Discrepancy harleynitelite Pentax DSLR Discussion 8 10-15-2009 12:46 PM
New k20d shutter count? striker99 Pentax DSLR Discussion 6 04-19-2008 04:59 AM
All times are GMT -7. The time now is 03:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
