01-07-2010, 06:52 PM   #1
Manual Focal Length Input
Hi,
I am using a few Pentax-M lenses on my K-x. They obviously work wonderfully, but when the camera first turns on it says "Input Focal Length". Since there is a difference between the focal length indicated on the lens and the ACTUAL focal length due to the crop factor, I was wondering which one I should put in. For instance, for an old 50mm lens, would I input the lens focal length of 50mm or would I account for the crop factor and put the actual focal length of 75mm?
Anyone know?
01-07-2010, 06:56 PM   #2
Sasquatch's Avatar
Enter the true focal length of the lens. If the lens is 50mm, enter that.
I just started fooling around with my K-m and my old lenses today as well. Use this very helpful blog if you get stuck anywhere:
Shooting manual lenses on Pentax DSLRs « robertsdonovan.com
01-07-2010, 07:02 PM   #3
Thanks a lot!
01-07-2010, 07:55 PM   #4
Lowell Goudge's Avatar
QuoteOriginally posted by WhichWayIsUp? Quote
Hi,
Anyone know?
Not to disappoint you but there is no difference between the lens focal length and focal length due to the crop factor. That is a mith,
Focal length is a physical characteristic of a lens, irrespective of the size or format of the film or sensor.
what really needs to be discussed is field of view relitive to format, but since that is harder to understand (i.e. 55 degrees as opposed to 40 degrees) the industry has tried to make it simple by making an incorrect technical statement.
01-07-2010, 08:34 PM   #5
Sasquatch's Avatar
Yeah that's what I meant too.
03-17-2012, 10:47 AM   #6
Just researching this "input focal length" as I just purchased a Voigtlander 58mm f1.4 from a fellow Pantaxian in Marketplace. The options for inputing don't allow 58, just 55 and 65. Is there a way to store the info for each manual focus lens (a la Nikon) ? What changes does my K5 make for differing focal lengths, is exposure affected, focusing?
Thanks for your input
03-17-2012, 10:48 AM   #7
Practically it shouldn't matter whether it thinks the lens is a 55 or a 58. I would go ahead and input 55 as it's the closest FL below yours.
03-17-2012, 11:06 AM - 1 Like   #8
Anvh's Avatar
QuoteOriginally posted by Franky2step Quote
It needs the number for the shake reduction, for the rest it doesn't really use the information for anything else.
The manual lenses don't have a digital information contact so the camera doesn't know which lens is on the camera so therefore no way to store this information.
With autofocus lenses, those lenses have the digital info contact and over that contact also goes the focal length information so no need for you to tell the focal length.
If you're using a manual zoom lens it might be better to turn the shake reduction off unless you know you will use the lens mostly on one focal length.
12-14-2016, 10:17 AM   #9
What about using a zoom...which focal lenth should be input?...minimum or maximum?
12-14-2016, 10:47 AM   #10
Just1MoreDave's Avatar
I try to guess where I'm using it most often, then keep in mind that the compensation might not be as awesome as I'm used to. I put in 135mm for a 70-200 and that works fine. A 28-200 is tougher - I might go with 50mm and try to be really steady at higher focal lengths.
12-14-2016, 02:24 PM   #11
MarkJerling's Avatar
QuoteOriginally posted by pcaple Quote
There's been numerous discussions about that. Most people seem to favor entering the mid-value. Some suggest entering the value that you'll most likely shoot at.
12-15-2016, 05:32 AM   #12
35mmfilmfan's Avatar
I use an adapter to attach my K20D to the eyepiece of my scope for digiscoping. My two eyepieces are 20x and 32x. These give relative focal lengths, apparently, of 1000mm and 1600mm. Since the maximum focal length I can input is 800mm, I always use that, and hope. The scope, of course, has no aperture control, so I use exposure compensation and get 'acceptable' results - my major problem is using it in a hide, with people walking around, shaking the floor and causing camera shake. With a hide clamp, things are no better, so I generally restrict myself to using it outdoors, tripod not fully extended to minimise camera movement. I turn SR off, of course.
Tony
50mm, camera, crop, factor, input, length, lens, pentax help, photography
Focal length input K(s)evin Pentax SLR Lens Discussion 6 10-27-2010 04:03 PM
What focal length input DutchAus Troubleshooting and Beginner Help 3 12-24-2009 09:15 AM
SR Focal Length Input for a Manual Zoom Lens? frank Pentax SLR Lens Discussion 13 03-15-2009 03:04 PM
Input focal length for a manual lens jpzk Photographic Technique 11 01-14-2009 08:50 PM
Input Focal Length lutzvo Photographic Technique 9 01-10-2009 02:51 PM
All times are GMT -7. The time now is 09:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
