01-09-2010, 01:37 PM   #1
Please help beginner - new lens testing
Hi, I was just testing the new lens (Tokina MF 75-300mm F4,5-5,6) and I m not sure (I m beginner) - is this lens "sharp" or "soft"? All photos taken from hand, in poor light conditions, snowing.
01-09-2010, 01:57 PM   #2
Damn Brit
Guest
I'm going to move this to the Beginners Forum, you'll get more help there. In the meantime, are the settings you included in the info the same for every shot?
For hand held they look as would be expected considering the focal length used. That isn't the way to test a lens though. You need to use a tripod to be sure.
01-09-2010, 02:16 PM   #3
GoremanX's Avatar
I wouldn't say they're soft, they look sharp enough. The problem is they're way under-exposed and dark, so the details don't show up properly. You need to learn more about proper exposure to get your pictures looking right. But that's beyond the scope of this thread.
01-09-2010, 02:20 PM   #4
Ash
Community Manager
Ash's Avatar
Testing a lens for sharpness requires more than a few handheld snapshots in poor lighting conditions.
It's likely that any perceived image softness is due to camera shake, inaccurate focusing and large aperture settings all acting in combination.
Consider using a tripod, use the 2 sec shutter delay and good lighting conditions for adequate focusing on a reasonably flat and detailed subject.
01-09-2010, 02:27 PM   #5
GoremanX's Avatar
Agreed. However, I don't think these pictures were all taken under poor light conditions at all. Some of them are clearly outdoors in daytime. "Overcast" is not a poor light condition. The picture is badly underexposed because the photographer is relying solely on the camera's light meter, thereby killing all detail.
01-09-2010, 02:30 PM   #6
Jewelltrail's Avatar
Everyone is right--the shots are underexposed and handheld, so not conducive to showing the lens' sharpness off. But, given the conditions, the shots look okay: the lens looks fine. Just practice some more, and, when out near 300mm with slower shutter speeds, use a tri-pod. Do not forget that lots of software is available to you to get better sharpness out of the pics.
01-09-2010, 09:11 PM   #7
Marc Sabatella's Avatar
QuoteOriginally posted by GoremanX Quote
It's good enough light that shooting at a wide aperture and a somewhat higher than base ISO, you should be able to get a shutter speed fast enough to combat shake. But we don't actually know what aperture or ISO was used here. Shooting at, say, f/8 and ISO 100, I wouldn't be at all surprised to find shutter speeds *well* below 1/300".
01-09-2010, 09:29 PM   #8
Damn Brit
Guest
Sorry, I didn't realise that info would get lost when I moved it. Info entered was -
ISO 400, Aperture 9.5, Shutter, 1/125s, FL 300mm
01-10-2010, 09:41 AM   #9
Wheatfield's Avatar
Your pictures are soft (and very low contrast), but because of your poor shooting technique, you haven't pinned down how good or bad the lens is.
beginner, camera, lens, pentax help, photography
Best prime lens for beginner? (28/50mm) SirJangly Troubleshooting and Beginner Help 37 09-10-2010 03:59 PM
Beginner: Which lens to start with 18-55 or 50mm? ninemm Pentax SLR Lens Discussion 35 08-25-2010 08:10 AM
Which Lens for a Beginner? jaieger Troubleshooting and Beginner Help 12 07-10-2010 06:12 PM
Beginner: Do I need another lens? Which one? sewebster Pentax SLR Lens Discussion 33 07-08-2008 03:09 PM
lens stuck, beginner needs help. Rantell Pentax SLR Lens Discussion 0 07-29-2007 06:42 PM
All times are GMT -7. The time now is 11:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
