01-12-2010, 08:05 PM   #1
Turning off built-in flash when using AF540 on K10D
Is there a way to turn off the built-in pop up flash on a Pentax K10D and use only an external Pentax AF-540FGZ flash in a wireless set up? I'm getting too much direct light on some photos that I want side and bounce lighting only.
Thanks
01-12-2010, 08:20 PM   #2
PrimeObjectif's Avatar
You can try to diffuse the pop-up flash to reduce the amount of direct light, but you can't use the 540 as a wireless flash unless you a wireless transmitter on your hot shoe and a receiver on the flash. I use the Cactus V4 system, and I'm pretty happy with it so far. You can also use the 540 off-camera with Pentax F5P cable.
01-12-2010, 09:13 PM   #3
Damn Brit
Guest
Have you set it to OFF in the custom menu. ON it acts as master, OFF it acts as controller. It will still flash but it will be a pre-flash and shouldn't affect the picture.
01-13-2010, 05:37 AM   #4
Thanks much; I'll give that a try. I wasn't sure, but thought that the means by which the 540 is activated is by the on camera flash sending a flash to it.
Thanks agaiin
J.T.
01-13-2010, 12:10 PM   #5
Marc Sabatella's Avatar
BTW, please try to give your threads more meaningful titles.
01-14-2010, 12:52 PM   #6
QuoteOriginally posted by Damn Brit Quote
I can't effin' believe I never knew that. Thanks, Gary!
camera, flash, pentax, pentax help, photography
K-r: built-in flash stopped working after using external flash wedge Troubleshooting and Beginner Help 7 01-12-2014 07:57 PM
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
K200D ISO when using built in flash? BobG Pentax DSLR Discussion 7 03-09-2009 01:10 PM
Inconsistent results using K10D's built-in flash jarnos Pentax DSLR Discussion 4 12-23-2007 07:22 AM
All times are GMT -7. The time now is 09:46 PM. | See also: NikonForums.com, part of our network of photo forums!
