Originally posted by Akiou Ever since I bought my camera, my flash has never worked right, and I am pretty sure I have read about this problem with others, but I searched for almost an hour in google and these forums and can't seem to find a fix for it, nor was there any help in the manual.
But my in camera flash totally overpowers every time, it completely blows the picture out to white and can not seem to find anything to change it. Is there some setting I am missing? Is it even possible to fix or is it like when the flash dies completely and then is basically dead?
And if it is broken, are there any cheap flashes I can buy? Namely for under $100(even less would be awesome, I am a student with very limited funds). One that moves vertically would be great, but it would be ok if it doesn't move if I can actually use flash for a change. :/
Thanks
What lens are you using? If it is a manual-focus lens, prior to the A-series (no "A" setting on the aperture ring), it is supposed to always fire at full power. The K10D has no way to read or control the aperture on these lenses.
If it is an A-series lens, an F, FA or DA lens, then it should not overexpose like that.
