Originally posted by crossing what this one indication of use compare with 1.7 : '' wide-angle prime 28mm 1:2.8 ''
As I said above, "i definitely recommend you do a search on the terms aperture, shutter speed, and ISO to learn how these relate and why aperture is important. Or get a book on photography." I'll add, I recommend you do that sooner rather than later, and that you add "focal length" to your search. Actually, search on that term separately; it doens't really have anything to do with the other three, but they are intimately related. Once you understand those terms, you're set.
Quote: will this lens ''Ricoh Rikenon P 50/1,7 ''(withaut P pin ) will work on my k-x ?
Once again, Google is your friend. Look up "Ricoh lens Pentax" and find the many, many references to lenses getting stuck on the camera because they have a different pin configuration. Once you've read through some of that, you'll be able to figure out if this particular lens will work or not. Hint: the phrase "without P pin" is a good thing in this context, but you will want to read up on the subject to know why.
