Originally posted by scimitar12 Mounting the lens is the easy part. What I don't understand how to set the cameras controls to acknowledge a screwmount is in place. I will take your advice and check the menu items along with re-visiting the manuals.
I'm not sure I would say that the camera "acknowledges" that a screwmount lens is mounted.
First, when you mount the lens, you must tell the camera the focal length, so it knows how much shake reduction to apply. As soon as you mount the lens and the camera detects no information from the lens, it will display a menu of focal lengths. Choose the one that is closest to the lens you are using.
You must enable the use of the aperture ring in your menus. I have a K10D, so my menus are a little different.
Since the camera has no way to operate the aperture stop-down pin on an M42 lens, you must switch the lens to manual mode. All Pentax M42 lenses that I am aware of had such a switch. If your lens lacks the auto/manual switch, you are limited to shooting wide open, unless you figure out some way to keep the lens stopped down. My recommendation in that case; use a different lens, with the switch.
I use my 50mm, f/1.4 Super-Takumar with the camera in Av mode, sometimes M mode.
I just use the lens the way I did on my Spotmatic: I focus wide open, half-press the shutter to activate the meter, stop the lens down to the desired aperture (watching the shutter speed and adjusting the aperture if the speed gets out of line), recompose and shoot. I should note that I almost always leave my meter in center spot mode. Thus the need to recompose after metering.
That's really all there is to it.
If SR is turned on, the camera will record the focal length in the EXIF data, but not the aperture, since it has no way of knowing that. Unfortunately, if you turn SR off for some reason, like a tripod shot, the camera will not record the focal length.
Non-pentax lenses that lack the auto/manual switch are problematic. I simply avoid them. If you have a particular favorite, then you will have to figure out a way to keep the lens stopped down. Some people have opened up their lenses and jimmied something inside. Others have used superglue on the pin. I can't recommend any of these approaches.
