Originally posted by peterh337 I've been looking at a program which simply converts the Pentax RAW files to high quality Jpegs, without renaming etc. Just very simple. But didn't find anything. So this remains an extra step, with the Pentax software.
If you're limited to the Pentax software, no way wou;d I consider shooting RAW - far too much bother. It's more modern "non-destructive" (parametric) image editing programs like Lightroom, Aperture, Photoshop, ACDSee Pro, Bibble 5, and Lightzone that make RAW palatable.
Quote: BTW I have bought some Sanyo ENELOOPs. I can see why they work in the Pentax cameras. They are not 1.2V. Coming off charge, they are 1.46V-1.47V
Maybe tested with a simple voltmeter, but tested under load, they do pretty much immediately drop to closer to 1.2V. But that's OK, because the camera is fine with a cell that can do 1.2V under load.
Quote: Whereas NIMH start at just over 1.2V.
Hmm, maybe burned out ones. The ones I've bought all show just like the Eneloops - tested with a simple voltmeter not under load, they show close to 1.5V right out of the charger, slow decline to 1.2V with continued use. But again, the issue is that when actually under load, these dip below whatever the actul threshold is far faster than Eneloops do.
Quote: The Eneloops are much heavier than the Lithium primary cells though
True, that's the one downside. Some people use Eneloops as their main cells and keep lithiums as the spares in their camera case, which strike me as a pretty good way to go when trying to minimize weight. Especially if you keep topping off the Eneloops often enough to avoid needing the lithiums most of the time (and msot source agree that with a decent charger, topping off modern rechargeables is perfectly acceptable).
