01-21-2010, 08:41 PM   #16
enoeske's Avatar
it wouldn't hurt to post an example so we can leaf through the exif data
01-21-2010, 08:42 PM   #17
MikesChevelle's Avatar
is there not a way to control my flash, other than buying an external one
01-21-2010, 08:48 PM   #18
QuoteOriginally posted by enoeske Quote
Um so the weirdest thing, I had been deleting them all, so I turned my camera on to take an other wash out and I got a perfect pic. Not sure what I did differently. ISO is on auto, shot on F5.6 at a shutter of 180. Really weird!?!?!?!?!?!?!?!?!?!
01-21-2010, 08:57 PM   #19
Nevermind, new it was to good to be true
here is a pic. Aperture ring was set to 5.6, ISO on auto and shutter at 180 (fastest with the flash popped)
01-21-2010, 09:00 PM   #20
Jewelltrail's Avatar
Lets forget about the Promaster lens for a minute and focus on the M 50mm--this will simplify things. If you are getting pics which are completely white, they have to be waaaaaaaaaaaaay overexposed--it is that simple. When using flash, you have 4 tools that control exposure: the flash; ISO; aperture setting; and shutter speed. But the flash always shoots max power with an M lens--nothing you can control here. You have full control of the other 3 variables though.
Switch to manual mode. Take the M lens in your hand, manually stop it down to f8, and look through the lens to insure it has stopped down, that it is not stuck wide open--before you slap it back on the camera. Next, set the shutter speed for 1/40th. Finally, set the ISO to 100. Now, if you are indoors and you shoot at these settings, there is no way you can overexpose the shot to the point that it washes out completely white. I do not own an Ist DL, but I'm confident the on-board flash is not powerful enough to wash out a pic, when the other settings are as described above.
Do this, and let us know what you get. From what you describe, it really sounds like the lens is stuck wide open, even though you tell us you see it opening and closing. So, be sure it is stopped down to f8, before you mount it on the Ist and shoot. n And be sure the other settings are as described.
01-21-2010, 09:05 PM   #21
bogiesbad's Avatar
QuoteOriginally posted by MikesChevelle Quote
Well if I turn the apurture ring I can see the diaphram opening and closing. I guess I just need to read the manual to figure this one out.
I do not have a green button though on my ist DL?
It was mentioned in an earlier post but I'm not sure you understood. When using older lenses you must allow the use of an aperture ring in the camera's menu.
Read this thread: https://www.pentaxforums.com/forums/pentax-beginners-corner-q/59272-shooting-...x-dslrs-f.html
Sorry if I misunderstood and you know this already.
01-21-2010, 09:10 PM   #22
The flash on your ISTDL is rated with Guide number: 51 (at ISO200/feet) or 15.6 (at ISO200/meter)
That means if you are using ISO 200, you should set your aperature to:
aperture = 51 / camera to subject distance in feet
e.g. if your subject is 10 feet away, then use f5.6 (which is closest to 5.1)
if you double your ISO, then you multiply the Guidenumber by 1.44
e.g. ISO 400, Guide number is 73.4 (feet)
in all cases, set your shutter speed to 1/180 (you can go slower but not higher than this)
Note: this should get you pretty close, but if you find it still a little too bright use the next smaller aperture (larger f number), if it is too dark use the next larger aperture (smaller f number) or you could just physically move forward or backward.
01-21-2010, 09:13 PM   #23
here is an other one
01-21-2010, 09:20 PM   #24
Did you use the above procedures to set your ISO, aperture and shutter speed to take this photo?
01-21-2010, 09:27 PM   #25
aleonx3's Avatar
Judging from the pictures taken, there are overexposed with the flash. Do you have one taken without the flash?
01-21-2010, 09:28 PM   #26
Well the more pics I take, the better it gets. I have shot the last few in ap priority mode and its not the worst. Also I noticed that I cannot set the flash to any auto setting.
01-21-2010, 09:31 PM   #27
Same settings with the flash down
01-21-2010, 09:41 PM   #28
Are you adjusting the aperture on the lens or camera? Because you cannot control the aperture with that lens from the camera.
01-21-2010, 09:41 PM   #29
mtroute's Avatar
make sure your shooting mode is not set to auto bracket. I have done this and spent 30 mins pulling my hair out trying to figure out why I was only getting 1 good shot out of every 3...
01-21-2010, 09:53 PM   #30
QuoteOriginally posted by basso4735 Quote
I am turning the ap ring
QuoteOriginally posted by mtroute Quote
In my menu, there is not an option to turn off auto bracketing, just two settings in the auto bracket menu
EDIT: In drive mode, I am NOT in auto braket mode.
Its weird sometimes I turn the camera on an everything is good, and others its not. I guess Ill use this 50mm prime for daytime, non flash shots and use my AF ProMaster for indoor shots
asahi, camera, co, flash, pentax help, pentax-m, photography, smc
Problem with KX picture defect kancho Pentax DSLR Discussion 8 08-23-2010 02:31 PM
picture problem TaoMaas Photographic Technique 6 04-30-2010 06:25 AM
Total flash newbie needs help... Javaslinger Troubleshooting and Beginner Help 3 02-24-2010 10:25 AM
K10D+540 flash problem using trailing flash wirelessly PaulT Flashes, Lighting, and Studio 4 01-18-2010 10:00 AM
Picture problem with K100D Ash Pentax DSLR Discussion 2 04-28-2007 07:37 AM
All times are GMT -7. The time now is 08:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
