01-26-2010, 07:35 PM   #1
iht's Avatar
Loose flash battery compartment door (AF-280T)
The battery compartment door on my AF-280T flash unit has become quite loose. I basically have to squeeze the door to get enough pressure on the contact for the unit to power on.
Any suggestions/ideas would very much appreciated.
Thanks in advance.
01-27-2010, 06:29 AM   #2
Mike Cash's Avatar
Check for corrosion on the electrical contacts on the door. I've had similar problems on another make of flash due to dingy contacts.
01-28-2010, 06:27 AM   #3
i use an elastic band... one meant for broccoli, wrapped around the flash body... if you need more pressure put some stuff under the band to concentrate pressure on the part that needs to be pressed in. it's a cheap fix and it works for my 360fgz
01-28-2010, 07:56 AM   #4
eccs19's Avatar
If your door is corroded, I've got a non working AF280 I've been keeping for parts. Drop me a PM, and I would probably part with it.
02-01-2010, 03:02 AM   #5
iht
iht's Avatar
Thanks everyone for your helpful suggestion. Have been very busy, but will check the door for corrosion and scour for an elastic band once I have a bit of free time.
I'm wondering if this is a common problem. The door does seem to be quite flimsy.
02-01-2010, 07:48 AM   #6
QuoteOriginally posted by iht Quote
I've had problems with the door on my 280T for years. I'm on my fourth rubber band now.
battery, battery compartment door, camera, compartment, door, flash, flash battery compartment, pentax help, photography, unit
istD battery compartment problem Vranx Pentax DSLR Discussion 11 08-01-2013 12:25 PM
K-7: loose memory door? Normal or defective? AirSupply Pentax DSLR Discussion 3 03-05-2010 11:11 PM
Opening frozen battery compartment snofox Pentax Film SLR Discussion 11 02-28-2009 03:18 AM
Battery compartment issue john_ven24 Troubleshooting and Beginner Help 8 01-31-2009 07:41 AM
problem with AF360 battery compartment Shaloot! Flashes, Lighting, and Studio 1 12-26-2008 02:14 PM
All times are GMT -7. The time now is 12:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
