01-27-2010, 09:58 PM   #31
RollsUp's Avatar
The exposure meter on the K100D is shown as numbers rather than as bars in the viewfinder. When the camera thinks the exposure is correct it'll show 0.0, over exposures will be shown as .5, 1.0 etc., while under exposures will show -0.5, -1.0 etc.
In the Custom menu you can set the AE-L button in Manual mode to three settings, Program Line, Tv Shift or Av Shift. If you choose Tv Shift the camera will change the shutter speed to what it thinks will be the right exposure, in Av Shift it'll be the aperture that changes, when you press the AE-L button after choosing the shutter speed or the aperture you want to use.
I hope this helps some.
01-27-2010, 10:27 PM   #32
Otis Memorial Pentaxian
photolady95's Avatar
The viewing, is that only if you have the camera set on Tv or Av mode? Reason I asked is, I've never seen those numbers while in full manual mode.
01-27-2010, 10:29 PM   #33
Damn Brit
Guest
QuoteOriginally posted by photolady Quote
That's right because the camera is giving over full control to you.
01-27-2010, 10:34 PM   #34
Testing Rollsup statement, I put the camera in Av mode. Still no numbers. It told me I needed to use the flash, but no numbers are showing.
I don't know if firmware makes a difference in this camera's functions, but when I got this camera someone had already flashed the firmware to the lastest ver. 1.02.
I guess what I really need to ask also is, someone with a K100D tell me which options they have set through the controls on theirs. Some of the settings I'm not sure what to set them as.
01-27-2010, 10:44 PM   #35
K McCall's Avatar
I went and dug out my K100D just to see what was going on.
photolady, I have to agree that I think you might have some of your terms mixed up.
To wit:
When I put my K100D in Manual (exposure) mode, I am determining both the aperture and the shutter speed. When I look through the viewfinder, I see three numbers across the bottom in green: The first is the shutter speed. I can adjust that by moving the thumb dial on the back. The second number is the aperture. I can adjust that by holding the "Av" button on the front and rotating the thumb dial at the same time. The third is the camera telling me what it thinks the photo is going to look (i.e., it's flash -3.0 because I have the lens cap on and it knows it's going to be WAY underexposed).
Manual mode has NOTHING to do with autofocus. Focus is controlled only by the switch on the bottom left-hand corner of the front of the body. "AF" means the camera will autofocus, "MF" means that I will have to manually focus. Regardless of whichever one you have the switch set to, the red rectangle will flash in the viewfinder when the camera thinks that something is in focus.
As for the top LCD: in Manual mode it shows you the shutter speed (time value) first, then the aperture, then the shots remaining. So far as I can tell, you cannot customize the K100D to show you the ISO at the same time, but you can choose in the settings to make the "OK" button in the middle of your controller show you the ISO when you press it (that works for the top LCD and the viewfinder).
01-27-2010, 10:50 PM   #36
K McCall's Avatar
I think this is where Alfisti thought you were confusing metering with autofocus:
That setting came from the autofocus I was using to try and meter the area.
Autofocus has nothing to do with metering. You can put the camera in any mode you wish and see what settings it chooses by looking at the top of the LCD screen if you can't see the numbers in the viewfinder. But the red focus light means nothing in terms of exposure settings.
Actually at one time the autofocus metering
See, the term "autofocus metering" does not exist. It's either auto-metering or just plain old autofocus, but those terms do not mean the same thing at all.
I hope it doesn't sound like I'm attacking you; I'm really just trying to help. If your viewfinder isn't displaying the metering numbers, then either something might be broken or you might be covering them up with the way you hold the camera to your eye (you kind of have to look down to see them, depending on your eyecup and your eye's position).
01-27-2010, 10:53 PM   #37
Damn Brit
Guest
The only time you get those numbers in the top LCD is in Av mode when you press the Av button to set exposure compensation (they will also appear in the viewfinder). I think we've all been getting confused.
01-27-2010, 10:56 PM   #38
K McCall's Avatar
Gary, I'm looking at my K100D right now in Av mode, and the top LCD shows the aperture and the # of shots remaining. As soon as I tap on the shutter, it shows me the shutter speeds it's choosing.
To be fair, I don't know what version firmware is on this camera.
01-27-2010, 11:07 PM   #39
Damn Brit
Guest
QuoteOriginally posted by K McCall Quote
And I don't have a manual. Press the Av button when in Av mode and you'll see 0.0 appear in the bottom right corner of the LCD.
01-27-2010, 11:11 PM   #40
How can I make you all understand I am not confusing autofocus with metering. I didn't mean for that to sound like you all are thinking I meant to say. I just meant I had the camera set on AF.
This is what I did today because I wanted to know what all auto settings on the camera would show me once the photo was taken. I set the camera on AF (autofocus), then Av mode, then put the lens on the "A" and went outside to do some photo shooting. When I got back inside, I moved the photos I had taken to my folder I had setup for today. I used FastStone Image viewer to check the "image properties" where in there I can view "details" and it shows me which F stop, and which shutter speed was used for each photo I took. I took photos in different locations around my yard.
Now what I see in the viewfinder is: Shutter speed, F_ _ and number of shots left. Also the little hand for shake reduction.
01-27-2010, 11:12 PM   #41
RollsUp's Avatar
I was referring to the settings in M mode.
What happens when you turn on the camera, look through the viewfinder and half press the shutter button?
01-27-2010, 11:15 PM   #42
Gary, I just did what you said. I turned on the camara, put it in Av mode, and pressed the Av button, I saw in the top LCD 0.0. And it's dark in my room, so why is there no other numbers showing?
I just said what I see in there. In M mode, I see shutter speed, and F_ _ it does not shot aperture settings with manual mode.
01-27-2010, 11:20 PM   #43
K McCall's Avatar
You DO see your aperture settings then; that's what the F_ _ is. If if says F5.6, then that's your aperture setting.
01-27-2010, 11:21 PM   #44
And keitha, I do appreciate your jumping in but you all might want to read what I said in post #40. I know the difference between auto focusing and manual focusing, I also know that auto focusing has nothing to do with metering, it only auto focuses if I set the camera to full auto mode.
I know what the F_ _ means, I just meant it doesn't show the actual numbers. f stop...........
01-27-2010, 11:39 PM   #45
Damn Brit
Guest
Ok, that's not going to help you with your immediate concern but remember it because Exposure Compensation is useful when you find that the exposure is off by just a little bit. You can adjust it in 1/2 or 1/3 stops (you choose which of the two in your custom menu).
Unfortunately this thread is becoming a bit of a 'too many cooks' situation.
Now for your immediate concern - Sorry if I'm repeating someone else.
Correct me if I'm wrong but, according to your very first post in this thread, I'm getting the impression you were setting exposure and aperture according to what you thought they should be not what the camera thought.
Based on that, the way to meter is to look in the viewfinder you will see three sets of numbers, Shutter speed, Fxx and the numbers on the right represent the camera meter. When those numbers are set to 0.0 that is when the camera thinks exposure is correct. If you turn the thumb wheel to change shutter speed (or press Av button and turn wheel to change aperture) you will see those numbers change. So if those numbers aren't 0.0 you just turn the wheel until they are. That's your exposure adjustment.
Are we getting to the bottom of this now?
camera, lot, pentax help, photo, photography, yard
Travel Shadows Rense Post Your Photos! 8 10-18-2010 12:30 PM
Macro From The Shadows Nitrok Post Your Photos! 13 06-21-2010 08:54 AM
Landscape Shadows Nitrok Post Your Photos! 24 02-21-2010 11:05 AM
Help! Shadows/haze on part of sensor on my K100D Marilith Pentax DSLR Discussion 4 08-27-2008 11:59 AM
Shadows..... PentaxPZ Pentax DSLR Discussion 6 06-23-2008 06:11 AM
All times are GMT -7. The time now is 08:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
