01-30-2010, 09:43 AM   #1
twokatmew's Avatar
? Crop Factor and Old Lenses
Hello, first post here. I just got my K-x with 18-55 lens a week ago. This is my first dSLR, but I did use a 35mm SLR back in the 1980s. I've also got a Canon S90, and I'm currently trying to wrap my brain around focal length/crop factor/35mm equivalency. So here's a real newbie question:
I understand how to calculate 35mm equivalents when using lenses rated for digital cameras. But ... say I got an old Pentax M 50mm F1.7. Do I multiply that 50mm by 1.5 for a focal length of 75 (35mm equivalent)? Unfortunately I still have to convert to 35mm equivalents to visualize the capabilities of lenses. As I shoot more, I guess I won't have to do that conversion. (I hope!)
TIA!
01-30-2010, 10:22 AM   #2
QuoteOriginally posted by twokatmew Quote
Yup. Fortunately that's all the crop factor is really needed for. It doesn't change anything else.
Yes, any lens you put on the camera you'd just multiply by 1.5 to get an idea of the view from a full-frame camera. The lens itself, of course, is still a 50mm and will always be so.
01-30-2010, 12:25 PM   #3
Marc Sabatella's Avatar
Right. Whether the lens was designed for film or digital is immaterial. All 50mm lenses have exactly the same field of view on a digital SLR. So if thinking in terms of crop factor helps you visualize the field of view of a given lens, then continue to use it, and use it precisely the same way whether a lens was originally designed for film or digital.
And yes, I'd assume at some point you won't have to keep doing that mental arithmetic, unless you end up continuing to shoot film as well.
01-30-2010, 12:55 PM   #4
twokatmew's Avatar
Thx!
Thanks so much! I do still have my old Fuji 35mm, but I don't plan to use it. It's more of a museum piece, like my old Olympia manual typewriter.
50mm, camera, crop factor, equivalents, lenses, pentax help, photography
compensating for crop factor jeans Pentax DSLR Discussion 52 01-28-2010 03:03 PM
Setting up focal point for manual lenses. consider crop factor? D4rknezz Troubleshooting and Beginner Help 7 09-23-2009 01:00 PM
Aperture x Crop Factor BBear Photographic Technique 24 07-03-2008 08:54 PM
Crop Factor Wheatfield Pentax DSLR Discussion 32 06-28-2008 01:20 AM
Crop Factor: What's the deal? tux08902 Photographic Technique 21 12-28-2007 07:30 PM
All times are GMT -7. The time now is 11:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
