Originally posted by DavoMrMac So, I have a couple of questions for Kx owners...
1. Will the rear screen in live view mode confirm which focal point has been used?
There is a focus point indicator in Live View, indicated by a small white box. By default, it starts in the center, but you can move it anywhere along the screen. If you use facial recognition autofocus and it recognizes a face, the focus point may switch to the facial tracking (indicated by a yellow box) and will follow the face automatically.
Quote: 2. Is it a real issue that it is not confirmed in the viewfinder?
This will depend on the person, but for me, it's not an issue. I mainly use center point focusing anyway, or remember what zone I set it to, then compose accordingly.
Quote: 3. Does the Kx always focus on the centre point?
If using 5-point or 11-point AF, the camera will try to use the focus point with a subject that offers the most contrast in sharpness. Whether this is at the center point or not depends on how you compose the shot. So, no, the K-x won't always use the center point unless you tell it to by selecting center-point AF.
Quote: 4. Is this something that Pentax could fix in firmware?
I don't see any problem to fix. If you use 11-point or 5-point AF, you're giving the camera a wide area to focus on. If the object that gives the most sharpness-contrast is not at center, it won't use the center focus point. If that's a problem with you, use selective-point or center-point AF.
Quote: 5. Is the low res screen an issue?
No. It works fine for checking exposure, and you can zoom in to check your sharpness.
Quote: 6. How do you rate the menu system?
It works fine. I like how there are a ton of customization options. Whether it be Pentax or another brand, you're going to have to learn the layout of the menu system, so it will never make sense until you start using it.
Quote: 7. If I follow my original thought and go for the Kx, somewhere down the line is there likely to be a good upgrade path (maybe to a K7 successor)?
I say start using the camera first, then when you consider investing more into the brand, come back and ask the question. By then, your options and priorities may change, and we can better answer the question.
Quote: 8. Is Pentax still going to be around in a couple of years, producing digital cameras?
Another crystal ball question. I'll bite this time and say yes.
- Jason
