01-31-2010, 07:08 AM   #1
Macro newb questions
Hi all,
I have a couple super-newb question about macro lenses.
1. If a lens is a "macro lens", what EXACTLY does that mean? I've seen macro photos (they looked macro to me - like CU of a bug) that weren't taken with a macro lens. And I've seen photos that are certainly not macro photos, but taken with a macro lens. So what does having a lens labeled as a macro lens do for you?
2. When used for macro photos, what does the focal length mean? How would macro photos look if taken w/ a 35mm macro lens vs. a 100mm macro lens?
Thanks!
Greg
01-31-2010, 07:31 AM   #2
As I understand it, a macro lens will focus closer than its standard or normal counterpart. For example a 135mm macro might focus down to 39 inches, where as a normal 135mm focuses to 55 inches.
A macro photograph (my uneducated understanding) is showing small detail in a large way, either an extreme close-up of a "normal size" object, or an enlargement of a tiny object (your bug for example)
Focal length has to do with the enlargement factor, which I don't really understand. You'll see some macro lenses rated at 1:1, 1:2, 1:4, etc ... which is how big the object is projected onto the sensor. Wikipedia has a lot of math to explain it better.
01-31-2010, 07:49 AM   #3
eccs19's Avatar
The focal length of the lens affects your working distance when doing macro work. Example, if your taking a picture of a bug, and your using a 50mm lens, you then take the picture again with a 100mm lens, you will be further away from the subject with the 100mm lens, but assuming that both lenses are 1:1, you will still get the same magnification.
01-31-2010, 07:50 AM   #4
boriscleto's Avatar
Let me Google that for you
01-31-2010, 08:21 AM   #5
jeffkrol's Avatar
QuoteOriginally posted by boriscleto Quote
That's cute.. a bit scarey but cute........
camera, lens, macro, pentax help, photography, photos
Need some help with macro questions boodiespost Troubleshooting and Beginner Help 13 12-12-2009 07:15 PM
Newb with K-x questions DSLRnoob Pentax DSLR Discussion 6 10-26-2009 09:56 PM
Macro help? (lots of questions) D4rknezz Troubleshooting and Beginner Help 15 10-05-2009 06:06 PM
macro lence for a newb Asgaroth Pentax SLR Lens Discussion 4 06-25-2009 12:11 PM
Newb questions about flashes emr Flashes, Lighting, and Studio 1 03-13-2009 02:12 PM
All times are GMT -7. The time now is 04:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
