Originally posted by stl09 They discussed Types of Focusing - they referenced Manual and Automatic, they recommended using Servo for certain types of shooting. Would this be the same as the AP.C setting on the Pentax's?
Yes. But be aware that this is the absolute weakest part of Pentax's AF system.
Originally posted by stl09 They referenced three modes - Single, Group and All Area. I'm assuming that the SEL on Pentax would be the same as the Group?? Although in the K-7 manual it references setting it to one of eleven points. I wouldn't call this a group but more like a roaming single point? If anyone could help to clear this up it would be greatly appreciated.
Right — no "group" option. "Sel" lets you manually select which single point is to be used.
