Originally posted by MikesChevelle For some reason I cannot open RAW files in CS4. I am using Picasa as a cataloger/importer, but I do not think that it is doing anything to my files.
You should be able to do it all on CS4 which you would also have the Adobe bridge.
I was on the same boat with CS3 but after a bit of googling, I was able to make it see the RAW thumbnails and open the RAW files.
One of the easiest way to do this is open CS4 > go to "help" which is on the upper right or the last selection starting from "menu" > then click that for the dropdown menu and click "updates..".
Once you click on updates, it would automatically update and should install all the available plug-ins so you can view RAW files.
Hope this helps!
