Originally posted by sterretje At occasion I'm reading that when using a remote to take a picture, the SR is disabled. I assume that this for all Pentax dSLR cameras. Is this correct? It however is not clear if this is the IR remote or the cable release. So to which mechanism does this apply?
I did check today on a K10D and a K100D with cable release/2 sec delay and the EXIF still says that SR is on so I assume that it is for IR only.
Thanks in advance
Actually if you're using 2 second delay, then SR is always disabled by default. At least that's how it is with the K-7, K-x and (I think) K20D.
Also, if the shutter speed gets slow enough, then SR is also disabled. (edit: this one is false, my bad)
Using a cable release does not necessarily disable SR. The cable release essentially acts exactly like your shutter button, and that's how the camera sees it. I am not aware if the same is true for the IR remote.
