02-04-2010, 10:48 AM   #1
Vivitar mount not fitting
I just received a cheap Vivitar lens from Ebay. I got excited and tried to test it out on my Kx when I noticed it was not attaching properly. It looks like an old K-Mount, except the inner part (the black instead of the shiny part) of the mount is longer. I carefully put it back to see if that was the problem and it looks like it is the only problem keeping it from fitting.
Is it possible to make it fit without ruining the camera?
02-04-2010, 11:01 AM   #2
There should be some very small screws on the silver part that hold the black part in place. Remove these and remove the black piece. It is probably hitting inside the camera.
02-04-2010, 11:07 AM   #3
RuiC's Avatar
QuoteOriginally posted by doorkey Quote
QuoteOriginally posted by wildlifephotog Quote
After taking that skirt out you may want to file/saw the excess, paint it black and screw it back.
See: http://forums.dpreview.com/forums/read.asp?forum=1036&message=17141294
02-04-2010, 11:35 AM   #4
I had a similar problem with an old Vivitar zoom. The directions linked by RuiC is one of the best references out there. The only catch with my lens was that the screws to remove the collar where on the time not the side. The screws are really small, so be careful. I also found that making the the initial vertical cut with a small file and then taking the rest down down with a grinding wheel on a Dremel tool was quite effective. Finally I polished off the final cut with some fine sandpaper.
02-04-2010, 11:52 AM   #5
Lowell Goudge's Avatar
just be sure to paint the cut surface to avoid glare.
02-04-2010, 11:59 AM   #6
I've made the modification myslef as well and it worked fine. I posted some photos as well here:
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/86020-old-lenses-k-x.html
02-04-2010, 04:25 PM   #7
I will give it a try tomorrow when I have access to the tools. Thank you for the help and the links!
camera, fitting, mount, pentax help, photography, vivitar
Vivitar S1 90 PK + 1.4x TC versus Vivitar 90 FD + mount TC adapter Pentaxor Pentax SLR Lens Discussion 3 10-24-2010 10:24 PM
A Fitting End paulyrichard Post Your Photos! 8 08-11-2009 04:32 PM
Change vivitar FD mount lens to K mount? meszidik Pentax SLR Lens Discussion 4 09-12-2008 09:59 AM
All times are GMT -7. The time now is 09:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
