Originally posted by Marc Sabatella The 125 is probably from testing at the factory. The 879 is probably because the SD card you used happened to already hae an 878 on it, and the camera was set to start numbering where the card left off.
I used a brand new SD card with my first K-x (formatting it in the camera before the first picture was taken) and the file number started at an odd 5665. The shutter count said mine had around 185 actuations, if I recall correctly.
When I got my new K-x, I used the same card from the old one (again, formatting it before the first pic) and the filenames started at 0001 like I thought they should (shutter count was only around 130).
I think it's an oversight from the factory to reset the file numbering or probably more likely, the firmware that was put on my first camera had the file number predefined from the camera(s) it was developed and tested on.
