Originally posted by HGMonaro Can't agree Marc. With a 1/8sec shutter speed, the majority of people will have already started to pull the camera away from their eye before the exposure has finished!
Well, if so, then that's simple photographer error, and easily corrected. But in any case, it doesn't matter. The flash will have already provided all the illumination they subjects are going to get. 1/8" at f/7.1 and ISO 1600 is not going to let in much light at all in comparison.
In fact I just tried this. I mean, I tried as hard as I could to *make* the picture come out blurry at those settings. No matter how much I moved the camera, I completely failed in my attempt to get a blurry picture. The light from the flash was so short it didn't matter how much I moved the camera - I got no blur. The only way I was able to get any blur was to shoot a scene that had so much light that it was already properly exposed at that those settings even without flash. But if that had been the case, then the camera would *not* have chosen those settings.
That's why I'm asking to see samples. I don't know about anyone else, but I've really thought this through, and those exposure settings should *not* result in blur if it really is a dark scene. it's common sense if you think it through and don't just assume 1/8" means blur. It shouldn't if flash is the dominant light source, and that's presumably what the OP is dealing with here.
Now, it's certainly possible the camera somehow missed in terms of gauging the ambient light - like if the metering off an especially dark-colored subject. So the standard advice on metering would apply. However, with correct metering, the mode in question *does* work. It really does. If it didn't, there's a lot of photography books that would need to be re-written, and a lot of great pictures taken using those kind of settings that would be unexplainable.
