02-05-2010, 07:12 PM   #1
pakuchn's Avatar
What am I doing wrong - Pictures attached
Take a look at these images.
Does this mean, I need to get a external flash or 50mm f1.4
02-05-2010, 07:21 PM   #2
I'm all for the use of external flash. In the second photo, your white balance is way off I'm sure. Unfortunately, no exifs attached so we cannot tell exactly what you are using. More information would probably help you get a better answer.
02-05-2010, 07:36 PM   #3
pakuchn's Avatar
This is the LEFT picture
Date and time original image was generated: 2010:02:05 10:33:59
Manufacturer: PENTAX
Camera model: PENTAX K-x
Exposure time, sec: 1/80
F number: 5.60
ISO speed rating: 1600
Lens focal length, mm: 55.0
Orientation: Normal
Copyright: M
File change date and time: 2010:02:05 17:31:30
Flash: Flash did not fire, compulsory flash mode
Exposure bias (APEX): 0/10
Metering mode: multi-segment
Exposure mode: Auto exposure
Focal length in 35 mm film, mm: 82
Scene capture type: Standard
Artist: M
Sensing method: One-chip color area sensor
X Resolution: 72/1
Y Resolution: 72/1
Units: 2
SoftWare: SILKYPIX(R) Developer Studio 4.0 English 4.0.30.0
YCbCrPositioning: Co-sited
Exif version: 0221
ComponentsConfiguration: YCbCr
PixelXDimension: 2848
PixelYDimension: 4288
FlashPix Version: 0100
Compression: 6
InteroperabilityVersion: 0100
02-05-2010, 07:38 PM   #4
pakuchn's Avatar
This is the RIGHT picture
Date and time original image was generated: 2010:02:05 18:19:08
Exposure time, sec: 1/30
F number: 4.00
Lens focal length, mm: 20.0
Orientation: Normal
Copyright: M
File change date and time: 2010:02:05 20:08:48
Flash: Flash fired, compulsory flash mode
White balance: Auto white balance
Focal length in 35 mm film, mm: 30
Contrast: Hard
Saturation: Normal
Sharpness: Hard
Subject distance range: Macro
Artist: M
X Resolution: 72/1
Y Resolution: 72/1
Units: 2
SoftWare: PENTAX Digital Camera Utility Ver. 4.11
Exif version: 0221
Colorspace: 1
PixelXDimension: 3936
PixelYDimension: 2624
Compression: 6
02-05-2010, 07:40 PM   #5
pakuchn's Avatar
Date and time original image was generated: 2010:02:05 10:02:17
Exposure time, sec: 1/60
F number: 4.50
ISO speed rating: 400
Lens focal length, mm: 35.0
Orientation: Normal
Copyright: M
File change date and time: 2010:02:05 20:37:54
Focal length in 35 mm film, mm: 52
Contrast: Hard
Saturation: Normal
Sharpness: Hard
Artist: M
X Resolution: 72/1
Y Resolution: 72/1
Units: 2
Exif version: 0221
Colorspace: 1
PixelXDimension: 4288
PixelYDimension: 2848
Compression: 6
02-05-2010, 07:49 PM   #6
Raybo's Avatar
QuoteOriginally posted by pakuchn Quote
F number: 4.50
Orientation: Normal
Copyright: M
Contrast: Hard
Saturation: Normal
Sharpness: Hard
Artist: M
X Resolution: 72/1
Y Resolution: 72/1
Units: 2
Exif version: 0221
Colorspace: 1
Compression: 6
Take a good look at the backround lighting.
02-05-2010, 07:51 PM   #7
Damn Brit
Guest
For the first shot, it says flash did not fire, for the second it shows AWB. I'm not sure if K-X automatically selects for flash when in AWB or if you have to set it to do so.
Regardless of that, the onboard Flash (or an external one for that matter) will give your pictures a harsh look without a diffuser.
In the second one, it doesn't say what focus point you were using but it looks like it's focused in front of the subject.
In both shots you have ISO 1600 which is giving you a long exposure. Set it to ISO 100 for flash.
Read up in the manual about Contrast, Saturation and Sharpness settings as well.
I'm moving this to Beginners Corner, the discussion will be more useful there.
02-05-2010, 07:53 PM   #8
Alex00's Avatar
Assuming your lens does not go below below f4, you need to higher your iso if you want to keep your expoure time fast to prevent hand shake. If you have a tripod, lower your iso and do long exposures like 1-2 seconds depending on the light available without overexposing.
I'm assuming you took those pictures without a tripod. Taking a shot at 1/30 requires a tripod unless you have a very stable hand.
Lastly adjust your white balance.
02-05-2010, 07:55 PM   #9
Alex00's Avatar
If you are using flash, lower the flash exposure to -1 so it doesn't come out too bright, put your shutter at 1/180 and iso 100. You would not need a tripod for this.
02-05-2010, 07:58 PM   #10
pakuchn's Avatar
K-x does not have ISO 100.
02-05-2010, 07:59 PM   #11
pakuchn's Avatar
Maybe I need to get a fast lens such as the 50MM f1.4 or Metz 48 flash.
I think the issue with "me" the end user, not the camera? Would you agree?
02-05-2010, 08:00 PM   #12
Alex00's Avatar
Lowest iso available to minimize noise since you have flash on.
02-05-2010, 08:05 PM   #13
Alex00's Avatar
Although 1.4 will give you few stops advantage in low light, you can take equally good pictures with your f4 if you used flash and adjust few setting with your camera properly. On the other hand in very low light situation where you do not want to use your flash then f1.4 is a must.
02-05-2010, 08:09 PM   #14
Damn Brit
Guest
Another lens and a Metz 48 wouldn't have helped you here, getting the settings right would.
02-05-2010, 08:10 PM   #15
twitch's Avatar
Aside from off WB in #2, and under exposure in #3, all three seem to have missed focus. How are you focusing? Are you using center spot and recompose?
Orbs and flare..just a crappy lens or technique? Pictures attached. Raptorman Pentax SLR Lens Discussion 18 01-21-2010 10:57 PM
attached images to gallery sabarrett Post Your Photos! 0 05-29-2008 01:59 PM
M42 -> K adapter - K2 attached monochrome Film SLRs and Compact Film Cameras 1 05-09-2008 09:59 PM
Need help to check lens. Pictures attached. drabina Pentax SLR Lens Discussion 9 05-02-2008 07:45 PM
Got my k10d!! (pics attached) crttr Pentax DSLR Discussion 11 12-25-2006 04:01 PM
All times are GMT -7. The time now is 09:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
