02-10-2010, 12:07 AM   #1
MikesChevelle's Avatar
Can I remove the "A" position lock on my aperture ring
I have a promaster 28-80 3.5. I enjoy having the "A" postion for when I just need a decent shot and want to shoot in auto mode. But for those times I want to go all manual, the pin to press to release the lock is right under the flash, and my fat fingers have a tough time doing so.
I know I can set the aperture electronically on the camera, but twisting the ring is just so much more convenient.
Can my total lens illiterate newbie self remove the lock so that I can just twist it out of auto mode with out having to press the small button
02-10-2010, 12:20 AM   #2
I don't know if you can remove the A position lock on that particular lens.
But I'd like to comment on this statement:
QuoteOriginally posted by MikesChevelle Quote
It may not so convenient as it seems. If the aperture ring is not at the A position, to get proper exposure, you have to:
- Set the camera to M mode.
- Hit the green button (or AE-lock, if there is no green button).
Even then, the exposure may not be correct (overexposure likely).
Think twice before modifying the lens.
02-10-2010, 12:33 AM   #3
KungPOW's Avatar
I'm thinking if you are too clumsy to work the "A" button, then you have little chance of opening, modifying, and closing a lens.
02-10-2010, 12:47 AM   #4
QuoteOriginally posted by KungPOW Quote
Amen. What are you thinking?
02-10-2010, 12:57 AM   #5
Its not a matter of clumsiness, its tucked fairly tight right under the flash housing, making it hard to get to.
02-10-2010, 01:20 AM   #6
Damn Brit
Guest
Photography isn't a race, take your time. If you have to, dismount the lens to move the A button (or move it before you mount the lens). If you're in a hurry to take a shot, you're not going to use the lens that way anyway.
Alternatively, shave one of your fat fingers down.
02-10-2010, 02:47 AM   #7
Yes, you probably can:
- with the lens off the camera, clamp the button down and carefully put epoxy around it - that'll hold it down permanently (don't glue the clamp to the button! - grease the clamp face.)
OR
- remove the lens flange & disable the button; this is risky business as you might lose the little ball bearing that makes the aperture ring click.
Practicing the use of the ewheel is more convenient in the long run than either of the above alternatives.
02-10-2010, 07:49 AM   #8
RioRico's Avatar
ON certain of my early M42 lens purchases, I found A+M operation bothersome. I superglued-down the aperture pins so the lenses were always manual. Now, I mightily wish that I hadn't done so. (I have yet to find a good superglue solvent.) That was before I'd learned to use SuperManual mode and the Green Button on my K20D. It's a BAD idea to permanently disable some lens feature, unless 1) you have REALLY good reasons, and 2) you REALLY know what you're doing. Better to suffer a little inconvenience now, than a scrapheap lens later.
02-10-2010, 08:01 AM   #9
Lowell Goudge's Avatar
try alcohol or methyl hydrate.
I think that is what they use when people get glued to toilet seats.
also I believe this breaks down with heat. try a hair dryer
02-10-2010, 08:04 AM   #10
why can't you just use manual exposure (set on the camera body) and adjust aperture and shutter using the camera controls.
That's why they are there.
i know it is not as easy with the single wheel on the *istDL you have in your signature, but it seems much better than your solution, where it is easy tio hit the aperture ring and take it out of manual.
That is why some of these buttons are difficult to get at in the first place, to stop you from doing it unintentionally
02-10-2010, 09:34 AM   #11
GerryL's Avatar
I think, acetone too is a superglue solvent.
02-10-2010, 10:38 AM   #12
Senior Moderator
Parallax's Avatar
Ether works well also. (Use with adequate ventilation!)
02-10-2010, 10:46 AM   #13
For those few times you want to go manual and use the ring, I suggest just dismounting the lens and move it off "A".
I prefer to use the camera dial instead of the ring when in manual mode because I can see the aperture setting in the viewfinder and I have the aperture setting recorded in the EXIF.
02-10-2010, 02:14 PM   #14
Canada_Rockies's Avatar
Nail polish remover works well, but you must work carefully so as not to dissolve something you would rather keep. The main ingredient is acetone.
02-10-2010, 02:18 PM   #15
Nowhere Matt's Avatar
I hereby pronounce this thread "Bananas" primarily based on the original post.
Maybe several feet of duct tape cut into thin strips or an appropriate C - clamp on that little bugger is what you are looking fer.
Bananas! Madness I say.
aperture, auto, camera, lock, mode, pentax help, photography, press
SDHC "lock" tab broken Thesorus Troubleshooting and Beginner Help 20 06-15-2012 10:18 PM
Sigma Mini-Wide 1:2.8 28mm set to "A" position Sadillah Pentax SLR Lens Discussion 6 10-14-2010 12:43 PM
what is "focusing helical position" and does my Sigma 105 care about it? WMBP Pentax SLR Lens Discussion 3 02-26-2010 11:42 AM
Suggestion don't remove price when marking a marketplace item as "sold" rpriedhorsky Site Suggestions and Help 5 02-08-2009 05:55 PM
FA 80-320mm doesn't work in f"A" position Edvinas Pentax SLR Lens Discussion 7 01-13-2007 01:46 AM
All times are GMT -7. The time now is 09:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
