02-10-2010, 03:58 PM   #1
Sigma Flash wont fire on my k10d when using cable
Hi guys
sorry i am new here hope this is the right place it feels like a beginners question.
I have a k10d and a Sigma EF-530 DGST i was bought a flash cable as a present ages ago and it never worked i email the company it came from and they said i was doing something wrong and time past.
so the flash works fine on the camera and i can press the test button when its off the camera and it will fire i plug the cable in to the hot shoe on the camera and the flash in to the one on the other end of the cable when i take a photo the flash dosnt fire.
if i zoom in and out on the camera the flash motors move just like it dose when on the camera so some signals are getting to the flash but it still wont fire
please any help
thanks
Alex
02-10-2010, 06:49 PM   #2
You can use a multimeter and check for continuity between both ends of the cord. You need to set the meter on OHM, then you put one probe on a contact at one end, and the other probe on the corresponding contact at the other end. If the current is going through, the reading should be zero (or very close). This should tell you if any contacts don't "communicate" with the corresponding ones at the other end.
02-10-2010, 06:54 PM   #3
bogiesbad's Avatar
Try wireless flash mode on K10...works with my Vivitar 285HV. Obviously you have a more sophisticated flash.
02-11-2010, 01:16 AM   #4
QuoteOriginally posted by flyer Quote
Thanks i shall try this
QuoteOriginally posted by bogiesbad Quote
i dont have the money to go buy a more expensive flash at the mo i would like to get this one working
02-11-2010, 10:18 AM   #5
ChipB's Avatar
Good suggestion from Yves - pay particular attention to the center pin as that's the one that actually "fires" the flash.
Also, since you said you were given the cable quite some time ago, make sure the cable you have has the same number of pins/contacts as the K10D and flash have (three surrounding the main center pin).
02-11-2010, 10:37 AM   #6
Alex,
I'm kinda thinking... there's a good chance you were given the wrong cable.... and the contact points don't even line up.
If this is the case then there's no way the flash would fire in TTL, which is probably what it's set to.
Try switching the flash over to Manual, and I wouldn't be surprised if the flash starts firing. If it does you'll have to learn how to set it up, for proper exposure.... however it really isn't that hard.
02-11-2010, 11:39 AM   #7
thanks for the help so far guys been looking how to fix this for ages this is first forum to get some good answers.
the cable has all the right connectors and the camera is speaking to the flash as with the flash connected to the camera by the cable the auto shutter speed of the camera changes to use the flash.
the cable says on it for pentax p-ttl
i have tried the flash in all 3 of its settings (TTL, Mh, Ml)
thanks for any other ideas that might help
Alex
02-11-2010, 11:55 AM   #8
QuoteOriginally posted by AlexMcCranor Quote
Alex
It sounds as if you have the right cable to use, but have you checked the continuity of all the pins, as flyer suggested, including the side of the hotshoe?
It is possible that one of the wires inside the cable, or in the end connectors, has broken. The "zoom" signal is probably not carried on the same connection as the "flash" signal, so one signal may be getting through, while the other is not.
As Chipb points out, it is the center pin that fires the flash. Therefore the center connector on the camera end must be electrically connected to the center connector on the flash end of the cable. The "ground", or common wire is the side of the hotshoe, the lip that physically holds the flash in place. Make sure that this is connected, as well.
02-11-2010, 12:38 PM   #9
so the lead works 2 a point as if i touch the conectors on the camera side of the cable the flash fires so the problem is with the connection from the cameras hot shoe to the cable or a setting on the camera not triggering the flash
02-11-2010, 03:14 PM   #10
I honestly can't see it being any setting on the camera.
However it may be that you don't have the flash on far enough to touch the contacts. I have this happen to me a fair amount, with my radio popper.
With my Pentax PZ-20 film camera my radio poppers didn't wok, although a standard flash would. It turned out being a piece of plastic molded onto the hotshoe, stopping the radio popper from sliding on far enough. Once I cut this plastic away everything worked perfectly. So it's something else you may want to look at.
cable, camera, fire, flash, k10d, pentax help, photography, sigma, sigma flash
Sigma 530 Super flash doesn't fire multi flash, any advice? pasipasi Pentax DSLR Discussion 4 11-25-2010 02:04 AM
Problem with Sigma-flash - won't fire ES80 Flashes, Lighting, and Studio 4 12-26-2008 11:55 AM
How to fire Sigma flash off-camera? NYpHoToGraphEr Flashes, Lighting, and Studio 12 10-23-2008 03:45 PM
K10D Shutter won't fire with flash popped up ChrisD1964 Pentax DSLR Discussion 1 04-25-2008 04:18 AM
k10d won't fire an old multidedicated flash hellrider Flashes, Lighting, and Studio 2 07-22-2007 07:01 AM
All times are GMT -7. The time now is 07:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
