02-11-2010, 04:56 PM   #1
Help with light meter
I'm not sure if this goes here or not, but if it needs to be moved, please move it for me.
hello all. I am currently a photography student and the camera I am using is a Pentax Spotmatic that belongs to my grandfather. I am having problems with the light meter (as is doesnt move reguardless of where I am aiming at light wise and the F-stops doesnt make a difference.)
I cant provide a picture of where my light meter is setting at but I can describe what my light meter is.
the light meter is a pin needle with the plus sign (+) on the top and the negative sign (-) on the bottom. the needle itself is directly below the middle gap and it moves so slightly when I aim it somewhere.
any help with this would be appreciated.
thank you ~ Srpickel
02-11-2010, 05:34 PM   #2
Did you check the battery?
If the battery is good, then the galvanometer is gone.
02-11-2010, 05:45 PM   #3
What is the Galvanometer? o.O
02-11-2010, 06:43 PM   #4
QuoteOriginally posted by srpickel Quote
For your purposes, that's the light meter.
Grab a nickle, turn the camera over and unscrew the plug on the bottom of the camera. There is likely an expired battery in there. Replace it. Note that you will not find a mercury replacement. Get a generic like an LR44. It isn't perfectly ideal and may introduce a slight metering error, but, it will drive the meter. Make sure you get the orientation right or your meter still won't work. If none of that works, then the meter is likely in fact, dead.
Manuals can be found here
Good luck,
02-11-2010, 06:53 PM   #5
Otis Memorial Pentaxian
For completeness sake, I have to ask the obvious...
Did you turn the meter switch on? Most Spotmatic models have a black slider switch on the side by the lens mount. When pushed up, it turns on the meter and stops down the lens. Here is a link to the camera's manual:
Pentax Spotmatic, Pentax SL, user manual, instruction manual
02-11-2010, 06:58 PM   #6
For your Spotmatic meter to be activated, do you need to push that little switch, located next to the lens mount and above the "x" and "FP", up on the camera? Try that if you haven't. You didn't indicate if your grandfather had given you a lesson on the camera when he gave it to you, so perhaps it's just been overlooked???
Best of luck.
02-18-2010, 03:49 PM   #7
QuoteOriginally posted by dnaseigel Quote
Best of luck.
My grandfather died when I was only 3, so I never knew him I went to this place called Welcome to see if anything could be done and they told me that it would be at least a month before I can get it back
If its that hard to fix a light meter, i'd rather buy me a new body or just use the camera without working >.>
Thanks everyone for your help
camera, help, light, meter, move, needle, pentax help, photography, sign
K-x as a light meter Eagle_Friends Pentax DSLR Discussion 7 10-15-2010 05:32 AM
K7 Light Meter eccs19 Pentax DSLR Discussion 2 09-27-2010 05:01 PM
Light Meter sam.p Film SLRs and Compact Film Cameras 10 08-05-2010 03:51 PM
Light Meter daacon Pentax Camera and Field Accessories 16 12-25-2009 10:09 PM
Using the K-m light meter - if it has one kitkat Troubleshooting and Beginner Help 14 07-11-2009 06:23 PM
All times are GMT -7. The time now is 02:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
