Originally posted by older not wiser
The problem with marking the hyperfocal distances on a two touch zoom like the standard kit lenses is that it is that the scale would have to be constantly changing as you zoom. The 18mm end has different optical properties from the 55mm end (the wider the angle the higher the depth of field).
That's the trade-off for using modern zooms -- flexibility vs uncertainty. Although I seem to recall early push-pull zooms inscribed with converging lines, showing the DOF at all focal lengths. Don't have any of those with me at the moment. Darn.
Quote: Unfortunately if you do not want to carry around depth of field tables the only other option is the DOF preview, that can get very dark on small f numbers.
In my bag I always carry an old Kodak Master Photoguide, which has a circular DOF calculator. Unfortunately, it only works for focal lengths of around 50, 75, 105 and 150mm, the 'normal' lenses for 135, 645-6x6, 6x9, and 4x5" cameras. This is good enough for the folders I carry, but not for superzooms. Hey, how about a photographer's killer iPhone app -- a universal DOF calculator?!?!?
