02-16-2010, 02:23 PM   #16
Wonder if that is a common issue with that lens?
02-16-2010, 03:59 PM   #17
Just1MoreDave's Avatar
QuoteOriginally posted by noahpurdy Quote
The only reason I want to clean it is because it DOES have effect on the images. I think it's a little silly that I've had the lens two months and have dust on the inside already.
Mine is a DA version 1 that I've been using a lot for 4 1/2 years. It's pretty clean, so I had to add some "dust" for this demonstration. The first photo has a clean lens, f8, about 50mm, tripod, 2s delay, ISO200:
Some "dust" on the front element:
Some "dust" on the rear element - I had to unmount the lens for this, so the photos don't quite line up:
The front element "dust", a dot of paper cut from a Post-it note:
The same dot applied to the rear element:
Comparing the full-size images, I can easily see the contrast is reduced, with maybe some color tint. The dot takes up a considerable percentage of the rear element, and the effect is more obvious. I have never seen a lens with that much dust.
camera, focus, lens, pentax help, photography
Pentax repaired my camera but.... kevinfox203 Pentax DSLR Discussion 7 06-05-2010 11:37 AM
Can my K200d be repaired? kevinfox203 Pentax DSLR Discussion 28 05-24-2010 07:51 PM
What did you have repaired? LeDave Pentax SLR Lens Discussion 9 02-26-2010 01:23 PM
da*16-50 to be repaired sinus007 Pentax SLR Lens Discussion 8 07-22-2008 09:32 PM
News Error repaired! Adam Site Suggestions and Help 6 09-10-2006 06:23 PM
All times are GMT -7. The time now is 02:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
