Originally posted by MariesMeow I have a 18-55mm and a 50-200mm.
I'm not familiar with the 50-200 so I don't know if both zooms have the same front diameter. If not, you'll need more than one set of whatever filters you want, or you may reserve certain filters for just one lens (and any same-diameter lenses you buy later).
Many filters necessary for film work are unnecessary (or worthless) for digital cameras. All filters add another layer of glass between the camera sensor and the world, with some drop in image quality (IQ) -- you can decide if that's important. We can break down filters into 3 classes - protection, common effects, and special effects.
PROTECTION: Clear (daylight) filters WILL protect your lens. So will a stiff lens hood, except from head-on projectiles. UV filters are NOT needed; those are for film. (For me, protective filters just get in the way - I only use them in harsh environments.) Any of the effects filters will also protect your lens. Some filters cost more than some lenses, so you must decide just what really needs protecting.
COMMON EFFECTS: As mentioned above, polarizers will darken skies and reduce reflections. The merits of circular vs linear polarizers are argued elsewhere, at length. Neutral density (ND) filters cut light and are useful if you want to shoot wide-open and/or with a slow shutter in bright light. Use a welding-glass filter, shoot a busy street with a 10-minute exposure, and all moving objects disappear. Graduated density filters are half-gray and half-clear, useful when shooting something like a bright sky and darker landscape together.
SPECIAL EFFECTS: As mentioned above, diffusion filters can give an image a unique softness. Most other effects filters can be simulated in image editors. The colored filters common in film work are mostly useless for digital, with the exception of spectrum-slicing, to exclude all but certain bands of color. The most common are InfraRed (IR) filters, which block various amounts of visible light. These are discussed at length elsewhere. I sometimes work with actinic (UV-violet-blue) light to emulate early B&W photo emulsions. Forensic and scientific photographers may use other spectrum-slicing filters to look for details unseen in visible light.
Similar to filters, but more optically active, are add-on lenses. These may be thin DIOPTER (close-up) lenses, which look like clear filters; or thicker close-up adapters; or wide-angle and telephoto adapters. The close-up add-ons can be handy if you don't have money or room for a macro lens. Wide and tele adapters are usually miserable crap with lousy optical properties, which some people nonetheless cherish. Cf. HOLGA.
I think that about covers the basics of filters etc. I could blather on about infrared and spectrum-slicing, but I'd better stop now. Some members here are probably tired of that.
