Originally posted by eyew For some reason I thought that was required (for focusing to infinity ?) as I had found cheaper adapters which didn't have that but was advised it could not do that. Think it was
sth like this one ? If it makes it easier to mount / dismount, I'm all for it....
To be able to focus to infinity, the adapter needs to sit flush with the camera's lens mount. That means the adapter can't use the camera's built-in retaining mechanism, which is on the front surface of the camera, hence the added spring clip on the side.
The second adapter you just pointed out has a flange on it that prevents the lens from sitting against the camera's surface, so the lens-to-sensor distance is off by a bit, thereby preventing infinity focus. However, this flanged adapter can make use of the camera's retaining mechanism, so the camera's release button functions as expected and no separate spring clip is required to lock the adapter into place.
So it's not the spring clip that's required for infinity focusing, it's the flush mounting.
Originally posted by eyew Again, apologies if I am hijacking this thread.
I'm pretty sure this has been covered to death in other threads
In the future, if in doubt, it's probably best to start a new thread. But since this is the beginners' forum, the admins are typically more lenient.
