Originally posted by Hemi345 The K-x actually has one of the biggest viewfinders of all the entry level dSLR competition.
The O-ME53 looks like it has a nicer eyecup than what ships with the K-x... I wonder if the little lens inside of it could be removed if magnification wasn't desired. I see some screws that look like this might be possible.
You might be better off (financially) finding a non magnifying eyepiece for that purpose. Overall shape of the O-ME53 is the same as the Pentax standard eyepiece, just thicker. It gives a little bit of viewing advantage in that you don't have to press your face against the screen as much. On the other hand, the magnifier WILL crop the viewfinder such that edge information is cut off all the way around. On my K20d, I find myself shifting view to see everything in the viewfinder. I considered buying one for my K7 but after comparing my K20d (with the eyepiece) against the stock view finder of the K7, decided against it.
All that said, the eyepiece DOES help me with manual focusing on the K20d using the Katzeye split screen. So if that's the purpose for buying one, I'd say go for it. But if you're looking for it to magnify the entire viewfinder (in normal view), leave teh O-ME53 on the shelf and spend your money somewhere else.
To install it, just slide the original one off and put the new one on. Nothing could be simpler (aside from swapping lenses).
