02-20-2010, 08:58 AM   #1
Baard-Einar's Avatar
Front and rear focus problem?
Hi.
While reading the forums, many are refring to front and rear focus problems. How do I distinguish between the two?
02-20-2010, 05:16 PM   #2
Marc Sabatella's Avatar
Front Focus (FF) = camera tried to focus on a given subject but actually focused in front of it
Back Focus (BF) = camera tried to focus on a given subject, but actually focused in back of it
User Error (UE) = you wanted camera to focus on a given subject, but it actually chose to focus elsewhere, since it can't read your mind
This isn't really a lens issue - most FF and BF problems are probably issues with the camera, not the lens. And most *reports* of FF and BF are probably actually actually UE.
The way you figure out if you have an FF or BF problem is to downlaod a good focus test chart like the one at focustestchart.com, or read a bunch of threads where people try to explain alternative methods of testing that ideally avoid UE, but usually fail.
I'm moving this to the beginner's forum, because it seems most appriate there. Could even be a sticky...
02-20-2010, 05:21 PM   #3
Thanks. There are a lot of abbreviations used in the threads, and it isn't that easy to catch them all. A dictionary would be helpful :-)
I would agree that UE is the biggest errors of them all, focusing is tricky, but why squeeze that trigger if wysiNOTwyw?
camera, focus, front, pentax help, photography
Front/Back Focus issue - Is it the camera's problem or is it the lens? vtqanh Pentax DSLR Discussion 10 09-26-2012 04:58 AM
Front/Rear Lens Cap Compatibility jaieger Pentax SLR Lens Discussion 1 09-04-2010 04:53 AM
Front vs Rear TC K-xx-500-user Photographic Technique 2 10-08-2008 08:09 PM
Front&Rear e-dials ivanp Pentax DSLR Discussion 4 05-07-2008 03:52 PM
Do I have a front focus problem? peted Pentax DSLR Discussion 21 12-06-2006 01:44 PM
All times are GMT -7. The time now is 02:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
