Originally posted by salsd I've inherited my father's Pentax Z-10 and associated lenses. I’m looking into purchasing a K7, however two of the lenses I’ve received are not Pentax.
One of the lenses is a macro (sorry, the only information I have on this is “2x APK Macro Teleplus MC7 with a code 5802205. I also has in green 1:1 - 1:3 0.45m/50mm, and in white 1:1.5 - 1:20 infinity / 50mm).
The other is a Takumar Bayonet zoom (1:4.5 80-200mm)
They both have a K mounting – ie they fit the K7DLSR but the K7 does not digitally read the aperture on these lenses. I was under the impression that you can manually override the aperture. Is this correct and would these type of lens suit this camera?
Sorry if some of this information is not presented in an accurate manner, I don't have any of the original manuals with the lenses and am fairly new to photography.
If your Takumar is a Takumar-A then it can be used in full auto modes on any pentax DSLR. Minus Auto Focus of course. If not, only manual mode in which you have to physically turn the aperture ring (make sure you set custom menu function to allow aperture ring).
Your other is not a lens but a teleconverter. What the information is telling you is that if you have a 50mm lens mounted on it, the ratio numbers are your macro magnification. Not all TCs do this. The APK? or is it PK/A? either way, if it has the contacts to pass info to the camera, it will allow auto modes such as Av to be used (with an A type or later lens). If you mount an A 50mm f2.0 lens on the converter and set it to 1:1 you will have a 100mm f4 Macro lens capable of 1:1 reproduction.
Here's an example from a similar TC and a pentax m 50 f2.0
Click image for full sized view
