Originally posted by NecroticSoldier Yes, Indeed I am! the dark room looks like a dark washroom! smells like one too... went in today... and got some fluid on my hand and it is green now!!! oh I see what you mean there, is there such thing as a filter that filters everything except for black and white?
Are you using C-41 process film (Kodak CN)? The only chemical I can imagine changing your skin color is the bleach from the C41 process (which I think is pretty toxic). Most black and white films use a process of developer, stopper, and fixer. None of which, unless very prolonged exposure would turn your skin green (dye it). That or possibly toner in making prints.
Uhm, No. It's the silver based coating on the film that makes it black and white film. Very simply put, Different colors and shades affect each particle of silver differently. When you develop the film you are basically washing the silver away, leaving the negative image. My memory may be backwards on this.. The more silver you wash away (so to speak) the lighter the image on the negative and hence, darker on the print. The stop bath stops that process. The fixer basically fuses the image onto the negative. The fixer is then washed away (as it too is a developer of sorts).
The color filters serve to change the makeup of the light hitting the film. I don't know how far your class will go into it but there are a lot of things you can do with processing. You can use different developers to affect contrast, grain, push the ISO, etc. You have to plan for these things of course. For example, you cannot push the ISO on a single frame of a roll of 35mm film. Different wet papers will affect your final print too. In addition to, the color of the light you use to print your photos. On multigrade papers you can go from dead flat no contrast to almost pure black and pure white. Fun stuff.
I'm glad that these types of classes still exist because they kind of force the budding photographer to put some thought into the final image. I think Everyone should begin photography this way.
