Originally posted by macky112 Hi all,
i tried both min and max values with both kit lens, and they produce same depth of field...
I don't know what the issue is here. I can CLEARLY see different DoF's in each of the pictures posted.
The first is the most notable going to number two with a much longer DoF, more is in focus.
The third and fourth, I believe you said you used the 50-200mm, has the most drastic DoF in number 4, being I'd guess only about an inch, seeing that the heart shaped glass bottles are not in focus while the edge of the kleenex box IS in focus.
I'm not sure you quite understand exactly what DoF really is, and how to achieve it maybe?
