03-02-2010, 11:31 PM   #1
Remote triggers with the AF-560...
Hey there I'm just playing around with some off camera eBay flashes triggered by remote(ctr-301's) it all works fine except when I use my AF-560 flash they wont sync with a shutter speed of more 1/30th, the flash still fires and the camera fires but no flashgun light is captured!
Anyone know how to fix this issue or what the cause may be?
Regards
Simon
03-02-2010, 11:39 PM   #2
Are you using the 540 in manual mode? Try replacing the batteries in the triggers.
03-03-2010, 02:15 AM   #3
Yep tried both of those! No luck!
03-04-2010, 08:02 AM   #4
The low trigger voltage of Pentax flashes can cause slow sync problems with these radio triggers. The internal circuitry has just a little too much voltage drop. I fixed my Cactus triggers by connecting the negative battery terminal to the hot shoe ground plate, bypassing one of the components in the reciever. Maybe something similar would work for your triggers. Here's the thread where I discuss this:
https://www.pentaxforums.com/forums/camera-studio-accessories/91628-cactus-v4...-cold-%3D.html
03-05-2010, 12:32 AM   #5
Thanx Dave, I'm just not that technical nor do I have a soldering iron. At least I kno what the problem is and can work towards fixing the error!
Thanx Again!
Regards
Simon
camera, fires, flash, pentax help, photography
Will a YN-560 Flash Blow Up My K-x? DaveHolmes Troubleshooting and Beginner Help 18 12-02-2010 10:52 AM
Wanted - Acquired: Wein Hot Shoe to Hot Shoe Safe Sync HSHSB 990-560 excanonfd Sold Items 0 08-26-2010 10:56 AM
Help with the Triggers please sureshgvv Pentax Camera and Field Accessories 8 04-01-2009 06:37 PM
Suggestions on remote triggers. jbrowning Pentax Camera and Field Accessories 2 06-06-2008 01:06 PM
Wedding/portrait shots using remote triggers and mutiple stobes. Peter Zack Photographic Technique 6 06-03-2008 01:11 PM
All times are GMT -7. The time now is 07:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
