Originally posted by twokatmew I would indeed like more detail on how you used PXP X. I just upgraded to X3, and I've been using PSP since v9, but I'm still far from an expert.
I normally do each step on a duplicate layer to give me the option of changing the opacity if I want. Item separated with a / are drop down toolbar menu options.
PP Steps in PSP X:
- Adjust/Color Balance - Smart White Balance box checked then move the eye dropper to the black part of Boris' eye.
- Lighten the face via this tutorial:
Move the Light - Tutorials
- Get rid of the couch with Object Remover Tool - No feather and no Blend. Sometimes you need to blend a couple of times and sometimes moving the Source Box to different places. Then use the Clone Tool at 50% opacity or less to clean up the transition lines from the Object Remover Tool. You can also use the clone brush at 50% opacity with the Blend Mode set to Lighten or Darken to transfer texture to the object remover area.
- Add 460 pixel white border to the bottom of the image (This will merge all the layers you have - I normally save my work as a PSPI file before adding the border in case I want to change something later.
- Use the Object Remover Tool & Cloning on the white border to fill it in with carpet
- Click on the Edit Selection Button on the Layer Palette and paint the back foot with a white paint brush. When you click on the Edit Selection Button again, the foot will be selected and can be copied.
- After you copy the back foot, unselect it by Selection/Select None
- To paste it on the front foot, Edit/Paste As New Selection and move it where it fits the best then unselect it by Selection/Select None.
- Use the clone tool @ 50 % opacity to blend the toes to the foot and to remove the fur color patterns that make it look the back foot. Please note: I should have copied more of the shadow of the back foot when I did the image above as the front foot should have a shadow.
- Save as a PSPI file if desired and merge all layers. Crop and Sharpen to taste with Unsharp Mask [I used Radius 1 - Strength 100 - Clipping 0]
The Object Removal Tool + Cloning will take practice.
Tim
