03-10-2010, 01:23 PM   #1
Vierfinder question
I just got my K7 (yay me!!!)
Anyway, I just finished setting everything up everything looks good, but
When I look through the viewfinder, it's not crystal clear as such. It's like there is a thin plastic film somewhere that I'm supposed to remove or something. I can see everything clearly enough and can use the camera without trouble, it's just one of those little things I noticed and thought I should ask about it.
Also, the only reason I even saw it was because I looked at a white wall and moved the camera.
Dunno, maybe it's supposed to be like that.
03-10-2010, 01:24 PM   #2
Ira
Does the K7 have the diopter corrector in it?
If so, spin it.
03-10-2010, 01:45 PM   #3
It has a slider but that's not it.
It looks like a matte finish almost, it's uniform in its appearance.
I just don't know what a defective part would look like.
03-10-2010, 01:50 PM   #4
pbo
pbo's Avatar
Maybe try wiping your viewfinder window?
03-10-2010, 02:09 PM   #5
Ira
Do you have another lens to check? Maybe it's the lens, or a smudge on the mirror.
Or maybe you just developed a cataract today, and it's a coincidence.
03-10-2010, 02:30 PM   #6
Yeah, it's not the window, that looks like it should. It's in the same place as the AF guide-lines.
03-10-2010, 02:49 PM   #7
GoremanX's Avatar
There's a reason why it's called a matte focusing screen
03-10-2010, 03:13 PM   #8
QuoteOriginally posted by GoremanX Quote
Ok, so that's the one that comes with the camera?
I feel like such a noob...
03-10-2010, 03:18 PM   #9
GoremanX's Avatar
QuoteOriginally posted by Ouroboros Quote
Don't feel bad. If your last camera was a point-and-shoot, it probably had an electronic viewfinder which can be any brightness the manufacturer chooses. Switching to a real DSLR can seem weird. But trust me, you'll learn to appreciate the optical viewfinder a lot more.
03-10-2010, 03:45 PM   #10
I guess I expected to see crystal clear optics through the finder, the pics come up sweet so it's not a lens or sensor fault. I'll get used to the way of doing things soon enough
03-10-2010, 04:55 PM   #11
pbo
pbo's Avatar
Well, if it was crystal clear, then everything would look like it's in focus - and manual focusing using the screen would be almost impossible. Also, if you try and look at the screen itself (don't strain your eyes!) you'll see some concentric circles etched on it.
03-10-2010, 05:53 PM   #12
jimH's Avatar
I don't have the best eye sight in the world, so nearly everything that I see in the view finder is false. So with the smaller viewing screen that I have with the smaller DSLR viewfinder, I have to rely on the camera itself to give me an indication as to whether I've gotten a good focus or not. With the old 35's I could focus manually, (or visually, if you prefer) with not too much problem. But with the smaller DSLR viewfinders, I find that isn't as good. So, if your eyesight is similar to mine, the confirmation from the camera, has to be your main confirmation.
03-10-2010, 06:56 PM   #13
monochrome's Avatar
QuoteOriginally posted by jimH Quote
Hi: It is a change, for sure.
Have you adjusted your diopter so the LED's are their sharpest? When you have done that, you can trust your eyes more than the focus confirmation, especially suing manual fccus lenses.
03-10-2010, 09:22 PM   #14
... With the old 35's I could focus manually, (or visually, if you prefer) with not too much problem. But with the smaller DSLR viewfinders, I find that isn't as good. So, if your eyesight is similar to mine, the confirmation from the camera, has to be your main confirmation.
I assume your old camera had a split focus screen. You are aware that you can buy 3rd party ones for most cameras? katzeye optics and focusingscreen.com are two names that I know.
03-12-2010, 12:32 AM   #15
Marc Sabatella's Avatar
Actually, I believe without some sort of finish (liek the matte finish, the viewfinder would show no usable image at all - light would pass straight through it rather than forming an image. Kind of like shining a movie projector on a window instead of a wall.
Hi, new here and a question ... eSFotos Pentax Film SLR Discussion 12 05-25-2009 04:46 AM
Hello and a question Robert Woll Welcomes and Introductions 2 01-25-2009 03:39 PM
question?? mfc General Talk 2 04-29-2008 03:04 PM
My first question cygnet Pentax SLR Lens Discussion 10 10-10-2007 04:36 AM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 11:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
