Originally posted by raymeedc I came across the ultimate solution from an unlikely source..... Donald Trump, on his website, states that whenever he gets a spec of dust on his camera's sensor or viewfinder, he tosses it in the trash & purchases another one. I haven't tried it myself yet, but it sounds like it should work.
There's another, cheaper solution, and it gives you FF shots so your wide-angle lenses are really WIDE. This solution is called: film. Get an old PK and/or M42 body, some cheap old lenses, and insert the 135 cartridge of your choice. Every frame is cleaned automagically as it emerges from the cart. Just brush off your lenses every now and then, and you'll never be bothered again. For super resolution, use a MF cam like a Pentax 645 or 67, or even a 6x9 folder (no lens changing required). Selah!
______________________________________________________
"There's more than one way to skin a cat," she mused,
as she pinned its little feet to the dissecting board.
