Originally posted by The Kurly One My daughter wants to sit in the box today and get her picture taken with her Barbies. The box is a white sheet around my Pool Table light
This doesn't sound like what we would call 'macro', which implies EXTREME close-ups. (Not unless your daughter is a Thumbellina the size of a Barbie doll!!) This sounds more like you're trying for shadowless shots, sort of like product shooting of stuff about a yard or two across. You can do this with your kit lens a couple ways, depending on what you want.
You could set the lens to very wide (18-20mm) and the aperture wide open, with your daughter and her dolls (THE GALS) lined up about the same distance from the lens. So you'll be in Av mode, aperture at f/3.5 or f/4, and focus carefully so the gals are all pretty sharp. Try shots varying the exposure plus and minus a couple EV's. Try tweaking the focus just a little to highlight details in faces. The picture should be a bit soft around the edges.
Or you could try for more sharpness. Now you must make sure that the gals are well away from the backdrop sheet (or the detail of its weave and draping will be distracting). Still in Av mode, set the aperture to f/5.6 or f/8. Focus a bit in front of the gals, say at a point almost halfway between them and your camera. Now shoot, again varying EV's and focus a little. Your goal here is to have them very sharp, but the background again fuzzy, not distracting.
These are ways of playing with DOF (depth of field), the zone of sharpness. In the first, just the faces are sharp, everything else is soft. In the second, all the subjects are sharp, but you've front-focused to pull them away from the backdrop. Give'em a try.
A little more: Here's something you can do with the28mm lens. Get the gals in the tent. Mount the 28mm. Set up the camera so the gals are all visible in the lens. Measure how far away from the camera they are, and the background is. Play with the lens, turning the aperture ring, seeing which f-stops line up with a distance that is just in front of the gals, and that same f-stop (on the other side) with a distance just behind the gals, but not as far as the backdrop. Here, you're trying to set a DOF that includes the gals but nothing else. Set that aperture and shoot; and again, try shots with varying EV's and tweaked focus.
