Originally posted by NecroticSoldier My DA L does not have quick shift, and I'm sorta paranoid now, my hands are kinda big, and on two occasions one of my fingers rested lightly on the focus ring, and I autofocussed it, and my finger gave some resistance to it. Is there a way to check for damage? I'm being really worried right now, anyone in this situation?
You can reduce the incidence of getting fingers in the wrong place by studying the proper way to use a lens/camera combination. Many people have never been told how to properly hold their rig, and you
might be one of them.
To properly hold an SLR or DSLR with a modest lens (up to my 50-135), the proper technique is to sit the camera in the palm of your left hand, with the thumb and forefinger on the zoom ring from below the lens. If you have the rig properly placed in your left hand, you can remove your right hand from the camera, and it will stay put. It takes practice to get it, but it is well worth the trial and effort. It even helps hold the camera more steady, adding to the shake reduction low speeds. This is obviously not much help when I have the 400 mm lens on the camera.
Many camera users hold the camera with the right hand and turn the zoom ring with the forefinger on top and the thumb on the bottom, which provides no support to the camera/lens assembly, and leaves the fingers that are not in use out by the focusing ring.
Those of us who grew up with square bodied cameras without grips learned very quickly that holding a camera like that can result in broken cameras. I can hold my K10 and 16-50 or 12-24 with one hand, thanks to the grip and the grip strap I have, but it is still easier to hold steady when the weight is sitting in the palm of my left hand.
