Originally posted by ragingtornado Just wondering if someone can explain the advantage of using "P" mode on the K200d (or any camera with only 1 dial).
The advantage over what? The advantage of P over Av, Tv, or M modes is that you don't have to have set anything - just point and shoot, and the camera selects both aperture and shutter speed for you. The number of dials is irrelevant. But it's true that if you like to select one of those parameters yourself on a regular basis, then P mode provides no advantage over Av or Tv. But if setting aperture yourself is something you like to do only occasionally, then leaving in P mode to have the camera choose aperture most of the time but you choose it yourself using the dial when desired beats having to change modes.
Quote: This seems to be the same as using "auto" mode.
No, because Auto doesn't allow nearly as many overrides as P. For example, no ability to select WB in Auto mode.
I'd say for most people who are not already used to working some other way, P would be their default mode. It makes the camera a P&S when you need it to be, allows for overrides when you want them, and a simple turn of the dial lets you select a different aperture/shutter speed combo.
