Originally posted by dmfw DOF is either set via. the lens or via. an internal camera menu/option, ex. AV and a wheel.
OK, but that's not a menu - that's a direct control, results visible in the viewfinder. There are as far as I know no menus anywhere on the camera that affect aperture. if you're looking at a menu, you are not controlling aperture.
Quote: The issue, does the Fstop set on the menu screen correspondence to the actual Fstop on the lens or a fake software based attempt to mimic the Fstop?
Again, no menus involved if you're doing it correctly. ut assuming you are doing it correctly - eg, Av and wheel - then yes of course it's actually closing down down the aperture on the lens.
Quote: My main issue, and one NOT addressed by any of the 12 replies, is for depth of field normal for this camera and lens or could the K-X + len kit be defective?
In what way did my previous response not address this? I asked what set your expectation of what the DOF *should* be. Without sample images, we have no way of knowing if what you are seeing is appropriate or not, but all I can say is what I already wrote earlier: DOF is gets shallower the larger the sensor, so yes of course your DSLR will have much shallower DOF for the same f-stop than your P&S. That much is 100% normal.
Quote: I have shot over 500 pics with the K-X, and the auto focus is too "random" for consistant results.
Are you letting the camera select the focus point or selecting it yourself?
Quote: I can use manal mode, but does not possess a good manual focusing system.
In what way do you mean that? You focus by turning the ring on the lens, and it works as well as any other DSLR.
